M92p Desktop Bios
  • hoaca388
    Badcaps
    • Jan 2022
    • 12032
    #41
    Originally posted by recep1982
    sorry sn:p8792hx
    thanks
    Serial number : PB792HX
    Bios file at # 33
    • recep1982
      • Aug 2014
      • 91
      • istanbul
      #42
      I tried but it didn't work. Actually, my own bios shows the image but it gives an EC error. bro sn: photo
      • recep1982
        • Aug 2014
        • 91
        • istanbul
        #43
        Hello, I wish everyone good luck. I wanted to share with you the bios and ec file that is working smoothly. tested OK without any problems
        • OK2BQN
          • Jan 2025
          • 5
          • Czech republic
          #44
          Hi, I have a motherboard from ThinkCentre M92P IS7XM ver.1.0 Model: 3218 AL7. Original BIOS: 9SKT80AUS revision: 9S80A Date: 24.04.2014. When flashing in Windows to a new BIOS downloaded from the LENOVO website according to the serial number, the upgrade crashed. I can get into the BIOS, but booting does not work. I do not know which chip the BIOS is loaded on. Which one should I unsolder. There are two. U4: MX25L6406E and U5: MX25L1606E. I would also need a correct new BIOS. I have a programmer. I did the upgrade because of the CPU, which the older BIOS could not handle. Thank you very much for your help. SN is S4NXNT3
          • peste
            • 13122
            • ROMANIA
            #45
            post them both..
            • OK2BQN
              • Jan 2025
              • 5
              • Czech republic
              #46
              I understood that I should overwrite U4(MX25L6406E) and U5(MX25L1606E). But I need the correct BIN file for each model 3218 AL7. Can someone please provide me with these files? Thanks in advance
              • recep1982
                • Aug 2014
                • 91
                • istanbul
                #47
                I had previously shared the BIOS and EC files that work without issues. You can try them if you want.
                • OK2BQN
                  • Jan 2025
                  • 5
                  • Czech republic
                  #48
                  recep1982 thanks for the advice. I have already downloaded your files from 27.12.2024. They seem to be the same as those from SMDFlea from 19.3.2019. I will compare them in the programmer and try them. Then I will let you know how it turned out. Thank you all for the advice.
                  • OK2BQN
                    • Jan 2025
                    • 5
                    • Czech republic
                    #49
                    I am reporting success, the motherboard is functional. But I had problems with desoldering with hot air. At 380 degrees Celsius I left it because I was afraid of destroying the chip. Probably a very hard soldering wave. I used the classic method with soft tin and a suction copper wick. After soldering, nothing worked. Again, the copper wick helped, which removed microscopic bridges. So for the M92P model 3218 AL7 motherboard IS7XM ver. 1.0 the above-mentioned BIOS is functional. Thank you all again for your help.
                    Zdenek​
                    • Aaron_wellz
                      • Feb 2023
                      • Malasia
                      #50
                      This is my read bios(not working) Please help me, Thank you !
                      Thinkcentre M92P , Type 3209
                      S/N: PBW03Z1
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12032
                        #51
                        S/N: PBW03Z1
                        Bios backup even if it is corrupted.
                        • ungrande87
                          • Oct 2021
                          • Argentina
                          #52
                          Originally posted by SMDFlea
                          Re: M92p Desktop Bios
                          Try this new bios,your ME area and bios was corrupt. Report back if its working .
                          As a side note to all the "Bios Collectors" ,this bios will not work on any other pc without changing some sections with a hex editor !
                          Buenos dias Amigo, te cuento mi situación: Tuve problemas al actualizar la BIOS y no me daba video el equipo. Actualice con la BIOS que compartiste y da video correctamente, el problema es que al reiniciar el equipo a veces no da video. Podrias revisar mis BIOS Originales??
                          Mi Equipo es: Lenovo ThinkCentre M92p
                          Machine Type: 3207
                          Model Number: A29
                          S/N: MJRDYNN
                          Espero puedan ayudarme, gracias
                          Good morning, friend, I'll tell you about my situation: I had problems updating the BIOS, and my computer wasn't giving me video. I updated with the BIOS you shared, and it was giving video correctly. The problem is that when I restart the computer, sometimes it doesn't give video. Could you check my original BIOS?
                          My computer is: Lenovo ThinkCentre M92p
                          Machine Type: 3207
                          Model Number: A29
                          S/N: MJRDYNN
                          I hope you can help me, thank you.
                          in English please..
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 12032
                            #53
                            Machine Type: 3207
                            Model Number: A29
                            S/N: MJRDYNN
                            Machine Type: 3207
                            Model Number: A29
                            S/N: MJRDYNN
                            in English please..
                            M92 Desktop (ThinkCentre) - Type 3207
                            • eleozz
                              • Apr 2016
                              • greece
                              #54
                              Hello, i have the same problem (corrupted bios)
                              Machine Type: 3237
                              Model Number: DM1
                              S/N: P8WBK8N (or P8W8K8N ?)
                              Product ID: 3237DM1
                              thanks in advance
                              • hotcrossedbuns999
                                M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                                by hotcrossedbuns999
                                My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                                1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                                2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                                3. I could only locate two chips that look like bios chips. Could someone verify this
                                01-03-2025, 12:32 PM
                              • macabook
                                by macabook
                                🧩 Initial Issue
                                07-24-2025, 02:17 PM
                              • grimacelord
                                by grimacelord
                                Hello there.
                                History:
                                03-15-2023, 03:29 PM
                              • AustinCER
                                HP ENVY Desktop TE01-1214 - No Display, Powers On, Corrupt BIOS
                                by AustinCER
                                I currently have an HP ENVY Desktop TE01-1214
                                S/N -
                                2MO22342GX
                                Motherboard - L75365-001
                                BIOS Chip - W25Q128JVSQ
                                Suspected Windows updates contained BIOS update in which, during update the Desktop PC displayed a black screen to the monitor while still powered on. Display image never restored.
                                Tested RAM in both slots, as well as new RAM. Tested a brand new known working i5-10th Gen GPU (Same CPU as original installed). Cleared CMOS. Tested the Desktop PC with a dedicated GPU connected, but still no display. Device will not POST when powered...
                                04-25-2025, 05:56 PM
                                by Vesko356
                                08-11-2023, 03:27 AM
