M92p Desktop Bios
  • hoaca388
    Badcaps
    • Jan 2022
    • 11700
    #41
    Originally posted by recep1982
    sorry sn:p8792hx
    thanks
    Serial number : PB792HX
    Bios file at # 33
    • recep1982
      • Aug 2014
      • 88
      • istanbul
      #42
      I tried but it didn't work. Actually, my own bios shows the image but it gives an EC error. bro sn: photo
      • recep1982
        • Aug 2014
        • 88
        • istanbul
        #43
        Hello, I wish everyone good luck. I wanted to share with you the bios and ec file that is working smoothly. tested OK without any problems
        • OK2BQN
          • Jan 2025
          • 5
          • Czech republic
          #44
          Hi, I have a motherboard from ThinkCentre M92P IS7XM ver.1.0 Model: 3218 AL7. Original BIOS: 9SKT80AUS revision: 9S80A Date: 24.04.2014. When flashing in Windows to a new BIOS downloaded from the LENOVO website according to the serial number, the upgrade crashed. I can get into the BIOS, but booting does not work. I do not know which chip the BIOS is loaded on. Which one should I unsolder. There are two. U4: MX25L6406E and U5: MX25L1606E. I would also need a correct new BIOS. I have a programmer. I did the upgrade because of the CPU, which the older BIOS could not handle. Thank you very much for your help. SN is S4NXNT3
          • peste
            • Dec 2016
            • 12742
            • ROMANIA
            #45
            post them both..
            • OK2BQN
              • Jan 2025
              • 5
              • Czech republic
              #46
              I understood that I should overwrite U4(MX25L6406E) and U5(MX25L1606E). But I need the correct BIN file for each model 3218 AL7. Can someone please provide me with these files? Thanks in advance
              • recep1982
                • Aug 2014
                • 88
                • istanbul
                #47
                I had previously shared the BIOS and EC files that work without issues. You can try them if you want.
                • OK2BQN
                  • Jan 2025
                  • 5
                  • Czech republic
                  #48
                  recep1982 thanks for the advice. I have already downloaded your files from 27.12.2024. They seem to be the same as those from SMDFlea from 19.3.2019. I will compare them in the programmer and try them. Then I will let you know how it turned out. Thank you all for the advice.
                  • OK2BQN
                    • Jan 2025
                    • 5
                    • Czech republic
                    #49
                    I am reporting success, the motherboard is functional. But I had problems with desoldering with hot air. At 380 degrees Celsius I left it because I was afraid of destroying the chip. Probably a very hard soldering wave. I used the classic method with soft tin and a suction copper wick. After soldering, nothing worked. Again, the copper wick helped, which removed microscopic bridges. So for the M92P model 3218 AL7 motherboard IS7XM ver. 1.0 the above-mentioned BIOS is functional. Thank you all again for your help.
                    Zdenek​
                    • Aaron_wellz
                      • Feb 2023
                      • Malasia
                      #50
                      This is my read bios(not working) Please help me, Thank you !
                      Thinkcentre M92P , Type 3209
                      S/N: PBW03Z1
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 11700
                        #51
                        S/N: PBW03Z1
                        Bios backup even if it is corrupted.
                        • ungrande87
                          • Oct 2021
                          • Argentina
                          #52
                          Originally posted by SMDFlea
                          Re: M92p Desktop Bios
                          Try this new bios,your ME area and bios was corrupt. Report back if its working .
                          As a side note to all the "Bios Collectors" ,this bios will not work on any other pc without changing some sections with a hex editor !
                          Buenos dias Amigo, te cuento mi situación: Tuve problemas al actualizar la BIOS y no me daba video el equipo. Actualice con la BIOS que compartiste y da video correctamente, el problema es que al reiniciar el equipo a veces no da video. Podrias revisar mis BIOS Originales??
                          Mi Equipo es: Lenovo ThinkCentre M92p
                          Machine Type: 3207
                          Model Number: A29
                          S/N: MJRDYNN
                          Espero puedan ayudarme, gracias
                          Good morning, friend, I'll tell you about my situation: I had problems updating the BIOS, and my computer wasn't giving me video. I updated with the BIOS you shared, and it was giving video correctly. The problem is that when I restart the computer, sometimes it doesn't give video. Could you check my original BIOS?
                          My computer is: Lenovo ThinkCentre M92p
                          Machine Type: 3207
                          Model Number: A29
                          S/N: MJRDYNN
                          I hope you can help me, thank you.
                          in English please..
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 11700
                            #53
                            Machine Type: 3207
                            Model Number: A29
                            S/N: MJRDYNN
                            Machine Type: 3207
                            Model Number: A29
                            S/N: MJRDYNN
                            in English please..
                            M92 Desktop (ThinkCentre) - Type 3207
                            • hotcrossedbuns999
                              M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                              by hotcrossedbuns999
                              My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                              1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                              2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                              3. I could only locate two chips that look like bios chips. Could someone verify this
                              01-03-2025, 12:32 PM
                            • macabook
                              by macabook
                              🧩 Initial Issue
                              07-24-2025, 02:17 PM
                            • grimacelord
                              Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                              by grimacelord
                              Hello there.
                              I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                              History:
                              1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                              I searched for this error online and discovered...
                              03-15-2023, 03:29 PM
                            • AustinCER
                              HP ENVY Desktop TE01-1214 - No Display, Powers On, Corrupt BIOS
                              by AustinCER
                              I currently have an HP ENVY Desktop TE01-1214
                              S/N -
                              2MO22342GX
                              Motherboard - L75365-001
                              BIOS Chip - W25Q128JVSQ
                              Suspected Windows updates contained BIOS update in which, during update the Desktop PC displayed a black screen to the monitor while still powered on. Display image never restored.
                              Tested RAM in both slots, as well as new RAM. Tested a brand new known working i5-10th Gen GPU (Same CPU as original installed). Cleared CMOS. Tested the Desktop PC with a dedicated GPU connected, but still no display. Device will not POST when powered...
                              04-25-2025, 05:56 PM
                            • Vesko356
                              by Vesko356
                              08-11-2023, 03:27 AM
