desktop computer bios havendale_hs
  • asliyucegsm
    • Jun 2011
    • 350
    • Turkiye
    my friends
    desktop computer bios dump
    mainboard:havendale_hs_75mmx75mm
    2mb dump
    25l1606e flash
    • 21853
    Re: desktop computer bios
    What pc model did this motherboard come from,the motherboard label is h55MXV ,its made by foxconn. The bios is 8MB
    http://www.foxconnsupport.com/downlo...keywords=&sort
    • asliyucegsm
      • Jun 2011
      • 350
      • Turkiye
      my friend has 8mb and 4mb file.
      my file is 2mb
      mx26L1606E
        • 21853
        • asliyucegsm
          • Jun 2011
          • 350
          • Turkiye
          my friend
          vendor foxconn
          FOXCONN LENOVO G41R L-IG41M DDR3_G41T-LMF(R63007) could this model be
            • 21853
            No, the G41R L-IG41M is socket 775 .
            Don`t you have the PC that the motherboard came from or are you just trying to repair the motherboard on its own.
            There may be some info in the bios, if you can post it i`ll have a look.
            EDIT: I looked at google images for the foxconn h55MXV ,they all have yellow pci-e sockets and a different layout. Are there any labels or silkscreens on the motherboard near the RAM sockets .
            • asliyucegsm
              • Jun 2011
              • 350
              • Turkiye
              Uploaded from own site Bios deleted
                • 21853
                What do you mean the bios is deleted. Your posted bios is 2,049 KB ,i trimmed it to 2,048 KB but can`t fix the ME area as theres no bios region. Is there another bios chip ? Also ,what PC did this motherboard come from, i asked already you but havn`t havn`t said .
                • kusal
                  • Jul 2021
                  • 28
                  • Sri Lanka
                  working bios 100% sure lenavo L-ig41m rv1/0
                  • Ahari
                    by Ahari
                    I...
                    08-13-2025, 06:12 AM
                  • mkdj
                    by mkdj
                    Dear all,
                    10-19-2025, 04:41 AM
                  • Habble7
                    by Habble7
                    Suspected Cause:
                    Troubleshooting Attempts:
                    05-22-2025, 07:28 AM
                  • haitham sharabati
                    [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                    by haitham sharabati
                    Hello engineers 😀,
                    I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                    🔧 Device Info:
                    - Model: HP 15-da2007ne
                    - Product Number: 8XF55EA#ABV
                    - Serial Number: CND0338P0D
                    - CPU: Intel Celeron N4000
                    - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                    💀 Problem:😅
                    - Device shows “Administrator Password”...
                    08-07-2025, 04:54 AM
                  • hotcrossedbuns999
                    M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                    by hotcrossedbuns999
                    My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                    1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                    2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                    3. I could only locate two chips that look like bios chips. Could someone verify this
                    01-03-2025, 12:32 PM
