Esc h61h2-mv (v2.0)
  • ay_bulut
    • Feb 2016
    • 114
    • turkey
    Esc h61h2-mv (v2.0)
    I'm searching for bios dump of this particular MBO
    NOTE : 8MB
    • 21841
    Re: Esc h61h2-mv (v2.0)
    Have you tried the one here: https://www.badcaps.net/forum/showthread.php?t=65250
    If it doesn`t work post your original bios backup .
    • ay_bulut
      • Feb 2016
      • 114
      • turkey
      ************** external link removed
        • 21841
        Try this one .
        • shahin843
          shahin843 commented
          Editing a comment
          Thank you . It works fine for me i3-3220 cpu
      • ay_bulut
        • Feb 2016
        • 114
        • turkey
        Try this one .
        thank you
        • bilisimindex
          • May 2022
          • Turkey
          If I install this bios will it see the video cards?
          • peste
            • 13550
            • ROMANIA
            until you try it you have no way of knowing ... don't forget to make a copy of the original bios of the laptop, before writing the bios chip ..
            • soumya199929
              • Apr 2022
              • 65
              • India
              I have a bios of different H61 motherboard that works with ECS/ACER H61H2-MV (v1.0) and it happens to be 8mb so i want you to try it .Also providing 6mb cap file for ECS H61H2-MV (v2.0). Try these and let me know if this helps.
              • bilisimindex
                • May 2022
                • Turkey
                Try this one .
                i tried it works :başparmak havaya:
                • soumya199929
                  • Apr 2022
                  • 65
                  • India
                  Thanks for conformation. Which file you have tested?
                  • bilisimindex
                    • May 2022
                    • Turkey
                    H61H2 MV2 NEW.zip
                    • ruzgarra34
                      • Aug 2017
                      • 6
                      • kayseri
                      thanks
                      • Ahari
                        by Ahari
                        I...
                        08-13-2025, 06:12 AM
                      • mkdj
                        by mkdj
                        Dear all,
                        10-19-2025, 04:41 AM
                      • Habble7
                        by Habble7
                        Suspected Cause:
                        Troubleshooting Attempts:
                        05-22-2025, 07:28 AM
                      • haitham sharabati
                        by haitham sharabati
                        Hello engineers 😀,
                        🔧 Device Info:
                        - Model: HP 15-da2007ne
                        - Product Number: 8XF55EA#ABV
                        - Serial Number: CND0338P0D
                        - CPU: Intel Celeron N4000
                        💀 Problem:😅
                        08-07-2025, 04:54 AM
                      • Citymin
                        by Citymin
                        S/N : 5RNK9FFT70...
                        08-05-2025, 05:12 AM
