ECS H61H2-M2 v2.0 bios
  • nixi22
    • May 2016
    • 44
    • Croatia
    I'm searching for bios dump of this particular MBO
  • IDislikemakingLogins
    • Feb 2017
    • 38
    • moon
    Re: ECS H61H2-M2 v2.0 bios
    Hi, if you have a de-funk dump and lucky enough you can use UEFI tool and use the .cap file from ecs website and attempt to fix a somewhat mangled bios.
    • nixi22
      • May 2016
      • 44
      • Croatia
      I already tried to repair it with content of old dump and new cap file but no luck.
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        post old dump
        Im Back... sort of...
        • nixi22
          • May 2016
          • 44
          • Croatia
          Here is broken dump
          • ala_borbe
            aka Donald
            • 1625
            • Malta
            something is wrong with your dump
            its 14mb????
            i fixed it to 8mb, if its bios problem it should work
            • see1001
              elo
              • Dec 2015
              • 39
              • turkey
              its 14mb????
              do not work.
              casper logo . work
              • bhcomputadores
                • Jun 2017
                • 16
                • Brazil
                Originally posted by see1001
                do not work.
                casper logo . work
                My thanks directly from Brazil. Bios working properly. tested with i5 3470. Bios was uploaded on an OEM motherboard similar to ECS. It was a MWX MW-H61-H2. 100% Running 3-Generation CPU
                • rajeshkumar
                  • Oct 2014
                  • 44
                  • india
                  Thanks working bios
                  • vickey_vip
                    • Mar 2016
                    • 134
                    • India
                    Another Working tested bios here
                    • Habble7
                      I need a BIOS dump for the Samsung S49CG934SU monitor
                      by Habble7
                      The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
                      Suspected Cause:
                      I suspect the BIOS may have been corrupted during a power interruption while updating the firmware. The official website provides firmware updates, but they can only be installed via USB flash drive.
                      Troubleshooting Attempts:
                      05-22-2025, 07:28 AM
                    • DynaxSC
                      MSI PRO B660M-G DDR4 - real bios dump from board needed (no stock bios)
                      by DynaxSC
                      Hi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
                      I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...
                      11-17-2023, 10:56 AM
                    • DynaxSC
                      Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                      by DynaxSC
                      I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                      It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                      I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                      11-06-2022, 05:22 PM
                    • vinaypundith
                      Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
                      by vinaypundith
                      I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
                      So, I'm looking for a BIOS dump for this machine - a 16MB one....
                      08-03-2024, 12:32 PM
                    • Buzzfuzz2k
                      Bios password removal on a Unowhy dump
                      by Buzzfuzz2k
                      Hi Everyone,
                      I'm facing a problem with a locked bios with a password and i can't find how to remove it...
                      The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
                      the Computer is a Unowhy small pc
                      N° UYM6524702229
                      After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
                      My first attempt was to get the bios dump from windows...
                      11-13-2023, 07:37 AM
