Apple Imac 820-2641-A bios request
  • lefos
    • Nov 2013
    • 321
    • Greece
    Hello everybody,
    I wanted your help on this one please. Problem I think is with the bios because after upgrading the OS now it turns on, shows nothing on screen and fans are spinning at high speed.
    I have attached the dump as it is right now.
    Does anyone have a working one or can fix this if it has problem?
    Thanks in advance!
  • lefos
    • Nov 2013
    • 321
    • Greece
    Re: Apple Imac 820-2641-A bios request
    Thanks for your response, but I think it is for a different board / device.
    It is also smaller than mine.
    • ala_borbe
      aka Donald
      • 1625
      • Malta
      here you go, password removed
      Im Back... sort of...
      • lefos
        • Nov 2013
        • 321
        • Greece
        Thanks a lot for your help!
        • lefos
          • Nov 2013
          • 321
          • Greece
          Hello again,
          Still trying to figure out the problem with this one.
          With the file from al_borbe I have the same issue.
          Schematic diagram is hard to find. Doing some measures I have 12V rail and on BIOS chip I can measure 3.3V. Already tried with a known working PSU.
          Funny thing is that problem occurred after upgrading the macOS. Already tried SMC reset. I have only the first led ON not the others. In order to power on the board the pwon switch has to be pressed and then connected the AC plug, but I have only fans spinning on high speed and nothing else (CPU doesn't heat up).
          Any tips ?
          Thanks in advance
          • toufik sat
            • Feb 2016
            • 134
            • los angles
            • rammstein9910
              • Feb 2019
              • 14
              Originally posted by lefos
              Hello again,
              Any tips ?
              Thanks in advance
              I know it's an old stuff, but I have the exact same issue, what was the solution in your case?
              • rammstein9910
                • Feb 2019
                • 14
                Just an update on this, figured out, so double checked the BIOS programmer's pinout, and used the firmware above, worked perfectly! Thanks for the share
                (After turn on the iMac had full blast on fans, totally blank screen, no blacklight at all.
                Worth to reprogram it a couple of times, and also use different AsProgrammer software.)
                • jbonavita
                  by jbonavita
                  Some issues
                  Things I tried
                  04-29-2025, 09:38 PM
                • zenius
                  by zenius
                  12-08-2024, 06:13 AM
                • Wahaz
                  by Wahaz
                  10-30-2023, 08:42 PM
                • hotcrossedbuns999
                  M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                  by hotcrossedbuns999
                  My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                  1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                  2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                  3. I could only locate two chips that look like bios chips. Could someone verify this
                  01-03-2025, 12:32 PM
                • David Gee
                  Bios Request HP 17-CN0023DX
                  by David Gee
                  I am currently working on recovering my HP Laptop (Model: 17-cn0023dx) after a BIOS corruption issue. The laptop is stuck in a no-boot state, and the Caps Lock light is blinking with a 3.2 code (3 long, 2 short), which according to HP documentation indicates a BIOS corruption failure.
                  I have prepared a USB stick using the HP Cloud Recovery Tool, but I confirmed that it does not include a BIOS recovery image for Crisis Recovery. I also attempted to extract the BIOS file from the spXXXXX BIOS update package provided on the HP Support site, but that update only provides...
                  05-03-2025, 09:58 AM
