8-pin NOR flash and bad flash update for MSI B350
  • Spork Schivago
    • Mar 2012
    • 4734
    • United States of America
    Hi. Do all of those 8-pin SPI NOR flash chips found in motherboards always have the same pinouts?
    I have an MSI B350 Tomahawk with a Ryzen processor. The BIOS was version 1.20. We couldn't get the RAM to run anywhere near what it was supposed to run at (3200 MHz). The CPU, motherboard, and RAM came as a packaged deal from Newegg. The newest BIOS is 1.90 I belive and says it fixes memory compatibility issues. We were just enabling XMP and it wouldn't POST. We tried updating the BIOS through the UEFIs BIOS update program.
    It wouldn't post at all after that. Just a black screen. I guess this is a common issue with these boards and these processors.
    Anyway, my spi programmer shows the MISO and MOSI pins switched compared to what the data sheet says. Would that matter? I would like to think all these 25xx flashes share a standard pinouts. There's only one BIOS on this board.
    This board has the 2x6 JSPI1 header and I have the pinouts for it. I can dump it and reprogram it in circuit. Just not sure if that really mattered or not.
    Thanks.
    Last edited by Spork Schivago; 12-09-2017, 12:53 AM. Reason: Fixed autocorrect making ttp
    -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
  • gabiz_ro
    • Mar 2011
    • 167
    Re: 8-pin NOR flash and bad flash update for MSI B350
    You are not alone.
    https://www.reddit.com/r/Amd/comment...i6&sh=17aa60c4
    Maybe this will help.
    https://forum-en.msi.com/index.php?topic=283908.0
    • Spork Schivago
      • Mar 2012
      • 4734
      Originally posted by gabiz_ro
      Yes, this is what I meant by a common problem with the Ryzen + AM4 + MSI combination. It appears not to be just the B350. This could be why certain MSI boards have the JSPI1 jumper next to the BIOS. I don't have a lot of experience with MSI boards, so maybe they've been doing this from the git go, but the J stands for Jumper, the SPI stands for Serial Peripheral Interface, the 1 is the first jumper of this type on this board (and the only). There are pinouts available. Some older boards have a 2x5 header, mine has the 2x6. I don't have the proper jumper cables to hook to it though, so I have to unsolder the chip.
      This is what I tried, kinda. I could not get the chip to be detected by my clip and the CH341A programmer I have, so I had to unsolder it. I flashed 1.90 directly to the chip, and resoldered. The CPU and DRAM lights come directly on, but that's it.
      Notice how the chip is a MX25U12873F but in the thread, they tell flashrom it's the MX25U12835F. I use a program called CH341A Programmer, version 1.31. It identifies the chip as a MX25U12835F as well. The sizes match just fine. My programmer uses 3.3v and I haven't had any issues with the chip frying, despite the datasheet saying the eeprom is 1.8v. The program I use lists the chip as an MX25U12835F, 1.8v. Perhaps the program can somehow change the voltage on my programmer?
      Anyway, here's where it gets a bit weird. I pull the NOR. I try flashing 1.90v, verify fails. I try over and over again, verify always fails. I compare a dump of what I burned and the original firmware. It always fails in the same spot. There was NVRAM data in that area. It was like the NOR wasn't properly erasing certain blocks.
      I did not try soldering it back on until I got the verify to match. I had to erase the NOR flash first, and then I was able to successfully burn 1.90 without having issues with the verify, but it still don't POST. I made a mistake and forgot to backup the NOR first, before attempting to flash 1.90 on there. I figured because it was bad flash, it didn't matter. This was wrong. Maybe that information needs to be there? Or maybe I should attempt to flash the original firmware version back on?
      I dunno. I had removing that chip. A good bit of work (unhooking everything, removing the board, unsoldering the chip isn't too bad, soldering it back on is a bit of a pain, putting it all back together, etc).
      I'll try flashing it again on board. Maybe my clip wasn't properly seated....
      • Spork Schivago
        • Mar 2012
        • 4734
        Oh, the original question remains though. Does having the Master Input Slave Output and the Master Output Slave Input switched for programming?
        With my clip, the way I had it setup, according to this programmer, the NOR flash's MISO and MOSI will be reversed. For whatever reason, I was able to burn and successfully verify the burn, so maybe when programming, it doesn't matter so much? Maybe it only matters if there's another SPI chip in slave mode? What do you guys think?
          • 30998
          miso/mosi are just clever names for tx/rx or in/out
          if you had them wrong, you would not be able to id the chip.
          • diif
            • Feb 2014
            • 6978
            • England
            The BIOS/UEFI update from manufacturers isn't usually the whole dump, just the update.
            What size is the chip and what size is the file from MSI ?
            Did i read right, you didn't backup the original ?
            • Spork Schivago
              • Mar 2012
              • 4734
              Yes, because it was a bad update, I did not backup the original. That was a mistake in my part. But I have success. The 16,384KB. The chip is 128Mb / 16MB, so to me, I looked at that as being a full dump from MSI.
              I redownloaded the original from the manufacturer again, just to make sure. I think the problem was the soldering technique I was using and wasn't getting proper connection on some. When I used the DMM to check continuity, I think it would add some pressure to the pin and make the contact.
              I ended up tinning the pads on the board, like I did before, then I'd push down on each pin of the chip. But this time, I went back through and touched the iron to the pad and the pin and added a dab of solder and just drew it to cover the whole pin and pad. As soon as I did this, I powered it up and it POSTed!
              • diif
                • Feb 2014
                • 6978
                • England
                That's good, I tried using one of those clips in the past but don't any more due to reliability.
                • Spork Schivago
                  • Mar 2012
                  • 4734
                  Ah shit. The DMI information was not stored in the BIOS. The UUID info is filled with all FF's. I believe that was there before, however, most of the other fields had originally said to be filled out by O.E.M.
                  I can use an editor to fill in the values for things like serial, but I don't know what the UUID was. Maybe it's calculated from the serial number? I think Serial and UUID where the only two fields populated before.
                  • Spork Schivago
                    • Mar 2012
                    • 4734
                    I noticed there's a new version of the program I use. It's written by a guy over in one of the Asian countries. Because I have the paid version, he was supposed to e-mail when a new version came out. I'm running 1.31. The latest is 1.34. I was looking at the change logs for the newer versions that I don't have, and I see that one says it fixes a bug with write and something with not properly erasing something. This could be why I had to blank the chip first....
                      • 30998
                      are you using a CH341 ?
                      • Spork Schivago
                        • Mar 2012
                        • 4734
                        Yes.
                          • 30998
                          it's now supported by flashrom.
                          http://www.flashrom.org/Flashrom
                          there is also some russian stuff.
                          https://github.com/nofeletru/UsbAsp-flash
                          • Spork Schivago
                            • Mar 2012
                            • 4734
                            I like how it's open source, but I like GUIs right now. On top of that, even though it might support my CH341A (or the clone of a CH341A), I don't see anything on the page you linked too about I2C support.
                            What I like best is with flashrom, people could support new chips to the database if they confirm they work or not. With the program I use (you linked me to it originally), the database is in a proprietary format, but does support a lot of chips.
                            flashroom still has a good bit of work that needs to be done I think. It doesn't list the MX25U12873F at all, just like the program I use, unfortunately, but flashrom does list the MX25U12835F, which my chip was falsely identified as with the program I use. However, flashrom does NOT list it as compatible.
                            I wish I had known before I fixed the PC. I would have tried and we could have updated the wiki.
                            I also wish I had the latest version of the program I use. I see there was a bug fix. I had a weird problem writing BIOSes to the MX25U12873F. Every verified failed, for whatever reason. I had to manually erase the chip, then it worked. For whatever reason, always, in the same area (or from what I could tell), it wasn't properly overwriting the bytes. I had it configured to write FF's first, and then the new data. But it always failed. It could have been that chip in particular and maybe that's why there's so many bad flashes (using the BIOS's M-FLASH utility or the Windows flasher). I dunno.
                            I don't understand what they mean by
                            Code:
                            Partial Windows support is available (no internal programmer support at the moment,
                            hence no "BIOS flashing").
                            The no internal programmer support is what is messing me up. flashrom is software, not hardware. I use my CH341A as the programmer. Why would this not work on Windows?
                            Still, flashrom seems promising. It'd be nice to have a program that works in Linux and Windows, and is open-source, stable, free.
                            **EDIT: Does the no internal programmer just mean if I'm booted into Windows and want to flash the BIOS on the machine I'm booted into, I cannot use flashrom to do it, but if I'm booted into Linux, more than likely, I can just run the program and flash the BIOS, without any extra hardware? Like a universal flashing program? Kinda like the Windows BIOS updater programs?
                            • gabiz_ro
                              • Mar 2011
                              • 167
                              offtopic
                              On CH341 I encountered many times problems writing some chips (random chips mostly from TV)
                              As a rule,after I backup original dump from chip,always do erase and blank check,result is no more problems.
                                • 30998
                                25 series are not i2c, they are microwire AKA SPI
                                • Spork Schivago
                                  • Mar 2012
                                  • 4734
                                  offtopic
                                  What software are you using? I wonder for me, if it's the programmer, the software, or the physical chip I was programming. What made me think for me it was the programming software, I saw this on the software page's changelog:
                                  Code:
                                  1.34 version 2017-7-8
                                  Repair S25FL256 read and write BUG
                                  1.33 version 2017-6-15
                                  Repair the previous version write \ erase bug will be reported
                                  That Repair the previous version write \ erase bug was the one I was thinking that was causing the problem. Google translate doesn't do the best job of converting Chinese to English, so we have to kinda try to figure out exactly what the sentence means.
                                  The mention about S25FL256 I don't think applies, but maybe the bug affected more than just the S25FL256? I wish I could have had a chance to try writing with the new software or tried that flashrom program, just to rule out the programmer and software.
                                  Thanks for sharing!
                                  • Spork Schivago
                                    • Mar 2012
                                    • 4734
                                    Yes, you're right, but my programmer supports I2C, which are 24xx series EEPROMs, I do believe. And although I run into a lot of the 25xx series, I have ran across a few 24xx series stuff. You follow?
                                    Thanks.
                                      • 30998
                                      there is a Linux programmer on sourceforge to do i2c on the ch341
                                      • Spork Schivago
                                        • Mar 2012
                                        • 4734
                                        Yes, but there's also the current program that I use, that does both of them. So instead of using two programs with probably no graphical user interface, I get to use one program with a graphical user interface.
                                        It'd be nice if both programs merged. That'd be kinda cool.
                                        • ekozeko333
                                          by ekozeko333
                                          🧠 What I’ve Done So Far
                                          Flashed...
                                          06-21-2025, 02:48 AM
                                        • corrize
                                          Nikon D800 camera - flash don’t work and capacitor don’t charge
                                          by corrize
                                          Hello, I'm stuck in troubleshooting…
                                          The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
                                          In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
                                          When I press the flash button, it's detected by the system, flash icon appear on LDC display....
                                          10-01-2022, 10:02 AM
                                        • Shadowtuy
                                          Bricked bios from a bad flash/update in a case of NO BACKUP repair question
                                          by Shadowtuy
                                          So I'm new here and have successfully unlocked a bios using "RCUnlocker" but after that I'm curious on recovery of a bricked bios from a bad flash/update in a case of NO BACKUP.
                                          The part I'm stuck on is my HP backup are a 32,768KB and 16,384KB image compared to a fresh bios from HP at 23,690KB. How would I use the fresh image to repair a flash chip? The guide I'm following just takes the image and flashes it over but clearly there is more to it.
                                          Just looking to expand my knowledge of this since the password removal worked great. Sorry if I missed this being...
                                          09-05-2023, 11:24 AM
                                        • Kashi1712
                                          HP Folio 1040 G1 corrupted bios - new bios flash, unable to update DMI
                                          by Kashi1712
                                          Hello all,
                                          I'm facing a strange issue, I do have my old bios where i can find some information about the laptop SN, build and so on for the DMI encoding.
                                          I did flash a new bios on the laptop and i have tried all the tools found everywhere on this forum and other forums but i'm unable to update all DMI info in the BIOS. I still get an error saying "Warning: Machine is not in committed state".
                                          Could somebody guide me on this or maybe help? I'm really hoping to find a way out of this bios thing...
                                          See attached old bios (corrupted...
                                          05-18-2023, 07:16 AM
                                        • akwky
                                          by akwky
                                          Hi!
                                          04-14-2025, 01:56 PM
