Hi, is anyone able to provide a bios dump for MS-7502 ver1.2? Can't seem to find it anywhere. Thanks
Bios dump for MSI MS-7502 ver.1.2(OEM Medion)
Re: Bios dump for MSI MS-7502 ver.1.2(OEM Medion)
Hi
Go to the web site for full bio update ...here is schematic if needed.
Techman1025Attached Files -
I have managed to make a .bin file from the official update from the Medion
website.
Attached FilesComment
Hi
Look good did you compare it with original back to make sure ending match and size? other then that it look good.
Techman1025Comment
by AhariHi all,
I...-
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
Channel: BIOS Requests ONLY!
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
Hello engineers 😀,
🔧 Device Info:
- Model: HP 15-da2007ne
- Product Number: 8XF55EA#ABV
- Serial Number: CND0338P0D
- CPU: Intel Celeron N4000
💀 Problem:😅
- Device shows “Administrator Password”...2 Photos-
by CityminHi all,
S/N : 5RNK9FFT70...-
- Loading...
