Asus Prime B450-Plus Bios Modification (USB Overcurrent)
  • ASB
    • Dec 2020
    • 139
    • Pakistan
    I have an Asus Prime B450-Plus motherboard with USB overcurrent shutdown problem. All the ports, voltages and resistors are ok. Can someone please help by editing bios to disable this feature? Another member (прямо) has successfully done this and shared the bios in forum but those are for other Asus models.
  • hoaca388
    Badcaps
    • Jan 2022
    • 12396
    PRIME B450-PLUS
    Cpu support : AMD
    • Fernon
      • Apr 2019
      • 16
      • Sri Lanka
      Can you tell how to do that?
      • ASB
        • Dec 2020
        • 139
        • Pakistan
        Originally posted by hoaca388
        PRIME B450-PLUS
        Cpu support : AMD
        No display and no beep without ram. Maybe this bios is for some other model.
        • hoaca388
          Badcaps
          • Jan 2022
          • 12396
          Your "original file" is 32MB and it's for Intel CPU => means someone put another model's file in and it's for Intel.
          • ASB
            • Dec 2020
            • 139
            • Pakistan
            I think there is some misunderstanding because both the original bios and update from asus are 16MB. Bios chip is GD25LQ128 (1.8V). MB is ok after bios reprogramming but problem returns after windows boot and shutdown.
            • hoaca388
              Badcaps
              • Jan 2022
              • 12396
              PRIME B450-PLUS
              • ASB
                • Dec 2020
                • 139
                • Pakistan
                PRIME B450-PLUS
                Same problem, when MB boots to windows after new bios, a Power Surge On Usb Port is shown though there is no short circuit/device connected to any Usb port and USB OverCurrent 15 seconds shutdown message reappears after reboot.
                • ezenia
                  ASUS PRIME B450 PLUS (rev 1.02) USB Overcurrent issue
                  by ezenia
                  So I bought a faulty ASUS PRIME B450 PLUS motherboard off eBay. They said it was water damaged and they cleaned it. The PC POSTs and displays a message that it's detected USB overcurrent and will shut off in 15 seconds. I verified this myself. So I did some checks at the ATX connector 1st to see if the resistance readings looked OK. I found the 3.3V rail measures just 179Ohms which seems way too low. It's been much higher on other AM4 boards I've worked on.
                  So I did some Googling to see what the potential culprits are. It varies from bad protection diodes, bad...
                  10-18-2025, 05:06 PM
                • Geomih
                  Asus Prime Asus PRIME X670-P r1.01X (60MB1BU0-MB0A06) boardview
                  by Geomih
                  Couldn't find this particular board on badcaps so here it is for safe keeping...
                  08-16-2025, 01:52 PM
                • DynaxSC
                  Activation of Management Engine after exchange Z590 chipset - ASUS PRIME Z590M-PLUS
                  by DynaxSC
                  Hi, i have an ASUS PRIME Z590M-PLUS board, which had an shorted Z590 chipset. I have succesfully exchanged the chipset to a factory new one, however there is a serious problem with the Intel Management Engine (later on: ME) not beeing activated after the chipset device replacement.
                  For lower chipset families (on ASUS boards) it worked to program the oldest bios version into the SPI rom, and the bios had activated the Management Engine itself by default - there was a message on the screen prior booting - "BIOS is updating Management Engine ..... . Do not shut down to prevent...
                  06-10-2023, 11:30 AM
                • RotVik
                  ASUS PRIME B550M-A AC weird behavior
                  by RotVik
                  Hello, I need a little help
                  I got an ASUS PRIME B550M-A AC Motherboard, bad BIOS, it wont display or boot, unless I did CMOS Restart first, after that It will boot but if I modified the configuration of the bios and saved it ,again no image
                  I got the BIOS .CAP file from ASUS official support, used a tool called ASUS CAP to BIN, and programmed it to the IC, soldered to the board and got it to boot correctly, all the way to Windows, but now the CPU fan stays at full speed all the time and if I try to power it off with power button it will restart instead, and there are...
                  05-01-2025, 04:59 PM
                • taurtnt
                  ASUS Prime Z490-P boardview
                  by taurtnt
                  need ASUS Prime Z490-P boardview diagram
                  Hi, I have an ASUS Prime Z490-P motherboard, it doesn't start and I need the boardview diagram, if anyone can help me
                  01-24-2025, 10:26 AM
