need bios for msi a88xm-e35 v2
  • anestef
    • Jan 2024
    • 8
    • GREECE
    hello i need bios for msi a88xm-e35 v2 please
    • 21869
    here. Version 6.5 extracted from bios update https://www.msi.com/Motherboard/A88XM-E35-V2/support
    • anestef
      • Jan 2024
      • 8
      • GREECE
      thank you very mutch
      • anestef
        • Jan 2024
        • 8
        • GREECE
        hello it seems what this file is too big for the chip
        it stops at 64%
          • 21869
          it stops at 64%
          What is your chip part number, what is written/etched on top of it. If you made a bios backup before trying to flash the new bios post it.
          • Cut.Sak
            • Jul 2022
            • Ukraine
            Can you help to clean bios password in my dump ?
            I have try to flash with your dump, but gave no initialization
              • 21869
              We can try, post your backup
              • Cut.Sak
                • Jul 2022
                • Ukraine
                Oh, unfortunately I can't to upload bin or 7z files. So I gave link for Google disk fie.
                https://drive.google.com/file/d/1pnf...w?usp=drivesdk
                • m1ch43lzm
                  • Mar 2019
                  • 914
                  • Peru
                  You can attach .zip or .rar by the way
                  Try, use English keyboard, case sensitive
                  Code:
                  Pass#blp997%
                  Shift-P for the first letter in "Pass"
                  # is Shift-3
                  b - beta
                  l - lima
                  p - papa
                  % is Shift-5
                  • mikeybass
                    by mikeybass
                    04-23-2025, 04:30 PM
                  • akwky
                    by akwky
                    Hi!
                    04-14-2025, 01:56 PM
                  • al3m0di
                    Update bios EFCN58WW to EFCN59WW
                    by al3m0di
                    Update bios EFCN58WW to EFCN59WW for solving The Connected AC adapter has a lower wattage than the recommended AC adapter
                    I have a Lenovo Legion 5 15imh05a device that I bought used online. It came with a 20V 8.5A 170W charger.
                    The BIOS version is EFCN58WW.
                    When I turn on the device, it displays the message:
                    "The Connected AC adapter has a lower wattage than the recommended AC adapter..."
                    The device rarely charges the battery, and even when it does, it doesn't show that it's charging.
                    I've tried
                    07-29-2024, 10:32 AM
                  • capoplays
                    Help with BIOS update on Dell G15 5515 after chip replacement
                    by capoplays
                    Hey everyone,
                    I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                    The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                    When I check the BIOS using the F12 menu Flash...
                    10-24-2025, 06:53 AM
                  • 0xx
                    2022 Razer Blade 14 (RZ09-0427) won’t boot after Windows update, only the green LED blinks - overheated or BIOS?
                    by 0xx
                    Hi folks,
                    My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
                    What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
                    I assumed that Windows Update was interrupted due to closing...
                    09-14-2025, 03:46 PM
