Pc Specialist GM7TGxP Bios and EC Problem
  • mburke26219
    • Aug 2023
    • 4
    • United Kingdom
    Hi All,
    Currently struggling with this bios and EC Problem and hope someone with more knowledge might be able to help, so my laptop PC Specialist Ionico 17 ( Tongfang GM7TGxP / 11800h rtx 3070 ) had lower than normal resistance on the PCH, so before i changed the pch i attempted to flash a bios/ec from same type of laptop board ( i am not the original owner and PC Specialist would not help ) which did flash ok but no change, after that i changed the chip and all resistance readings from all rails were normal, so i turned the laptop on with the new PCH and it turned on as soon as i plugged the power in (did find that strange but ok ) then laptop would attempt to boot but but after 1 minute turn off, so i checked the power rail and give myself a small scare when the cpu had 1.8 on core... turned the laptop straight off, the PCH Was new and all seem fine but then i though that i had the bios from the one i found online ( attached under 111bbb ) when i re-flashed the original bios then the same as before, i got 19.5v / 5v / 3.3 / 1.8v and all ok up to 1.05 and the laptop seems to not be starting the PM States, if anyone has a answer or solution please let me know, i have attached all files.
    Thanks,
    Matt
    • 20865
    Post the laptop serial number. Is that the original bios or the other one you tried. Where did you get the PCH from, was it from a donor, and if so from which motherboard model or was it from somewhere else.
    • mburke26219
      • Aug 2023
      • 4
      • United Kingdom
      The PCH Was from AliExpress, the laptop serial number is 218949901, image attached.
      111bbb is the one i had installed after the replacement PCH, the original is GM7 Original.
      Thank you.
      • peste
        • Dec 2016
        • 12786
        • ROMANIA
        Thank you.
        Don't post pictures unless asked...write with the keyboard..
          • 20865
          Thank you.
          Was the new PCH listed as new ,or from a GM7TGxP board
          • mburke26219
            • Aug 2023
            • 4
            • United Kingdom
            [QUOTE=SMDFlea;n3696993]
            It was listed as new, product code HM570 SKRMA )
            • Vesko356
              by Vesko356
              08-11-2023, 03:27 AM
            • zenius
              by zenius
              12-08-2024, 06:13 AM
            • JoWed
              Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
              by JoWed
              Hello Community,
              I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
              07-01-2025, 09:32 AM
            • TraJikar Mac
              [HELP] G712LWS BIOS capsule
              by TraJikar Mac
              I need someone that can capsulate one of the bios files below, and i prefer the older bios version so i can flash it using CH341A tool into the bios chip.
              The manufacturer BIOS files are bigger than the BIOSbackup1.bin files by 256KB and I don't know how to fix or recompile it.
              You can see in this link a conversation between me and other people (Starting at page 10) who tried to help me (thanks to their efforts), but i still couldn't fix it and the laptop is considered as dead until now.
              Also, I uploaded a backup file for the bios that I extracted by using CH341A...
              06-11-2025, 01:35 PM
            • mikeybass
              by mikeybass
              04-23-2025, 04:30 PM
