Corrupted BIOS on Asus Prime H510M-E R1.00
  • Pedro Ramírez
    • Jul 2024
    • 21
    • Chile
    Hello, my computer lost its image due to a problem with the graphics card (it was shorted out). Now the computer only turns on the fans but I have no image. Could you please help me with the BIOS? I've attached a backup.
  • hoaca388
    Badcaps
    • Jan 2022
    • 12314
    PRIME H510M-E
    • razor_amd
      by razor_amd
      12-15-2020, 07:07 PM
    • grimacelord
      by grimacelord
      07-10-2025, 02:52 PM
    • DynaxSC
      by DynaxSC
      06-14-2024, 03:49 PM
    • oragano
      ASUS ex-b250-V7 motherboard bios corrupted - by me
      by oragano
      hey all, i did a silly thing and flashed bios to perfectly working board. None of the asus official download bios would work with ez flash. They all gave error saying not supported bios file. I tried using uefi tool to extract it to a bin file but then ez flash wouldnt even recognise it.
      So, i used freedos and afudos with the aforementioned bin file i extracted and forced the issue. After bios reprogram, reboot and it was dead. Fans spinning but no post.
      i have a bios writer and none of the .cap files from the official site work either. I just get one spin, then off, then all fans...
      10-17-2024, 02:53 AM
    • jbonavita
      by jbonavita
      Some issues
      Things I tried
      04-29-2025, 09:38 PM
