Main board X541UVK REV: 2.0 Clear password
  • xloomx
    • Oct 2020
    • 58
    • Argentina
    I have this Asus with password bios, i try decod with the post (ASUS TP412 PFA)
    https://www.badcaps.net/forum/troubl...=2#post1544866
    but, i cant find the string...so, Ineed help. The bios is attached.
  • xloomx
    • Oct 2020
    • 58
    • Argentina
    MODEL X541U
    S/N: J5N0CX05B302195 CN:GXBB
    X541UA-G01713T
    Data of machine!​
    • bbanana
      Father Land
      • Oct 2021
      • 164
      • Vietnam
      password: noentiendonada
      • xloomx
        • Oct 2020
        • 58
        • Argentina
        Thanks, my friend😁 for the pass~!!!. Do you have a picture showing where the first line of the hexadecimal is? I don't understand the length of the string. I couldn't figure it out in order to use the XOR calculator.
        • TheIbz
          LG 34GN850-B full-screen vertical stripes β€” diagnosed to the main board, sourcing from China.
          by TheIbz
          My 34GN850-B (2023 unit) suddenly started showing dense vertical stripes across the entire screen β€” backlight fine, image actively driven but completely shredded. OSD doesn't render either, which rules out GPU/cable/source. Tore it down and did the full diagnostic pass:
          - Reseated and cleaned the LVDS/data cable at both ends (board side P302 and panel side CN1) β€” no change
          - Backlight connectors (F1/F2) reseated β€” no change (backlight was never the issue)
          - No bulged caps, no burn marks, board visually clean
          - This model has no discrete...
          09-22-2026, 10:25 AM
        • Dani_2024
          by Dani_2024
          10-28-2024, 05:06 PM
        • ygorsan
          by ygorsan
          🧩 Problem Summary:
          • I
          07-28-2025, 08:34 AM
        • tvguy12012012120
          Picture degrades over ~2–3 minutes (washed out / low contrast) – panel vs T-CON/FRC vs main board diagnosis help
          by tvguy12012012120
          I’m troubleshooting a Westinghouse WD55UW4620 with a strange, very repeatable failure mode and I’m looking for insight on whether this points to the panel itself, T-CON/FRC board, or mainboard.
          Any ideas as to what would cause these symptoms?
          Symptoms:
          • From cold power-on, picture is perfect.
          • After ~2–3 minutes, the image slowly degrades:
            • contrast collapses
            • colors wash out / look incorrect (greens especially bad)
            • image looks β€œmilky” / flat
          • Turning the TV off for a few minutes fully resets it; behavior repeats almost exactly each time.
          • Internal
          01-07-2026, 03:30 PM
        • frannyjunk
          Onn model 100012585 main board transistor is blown
          by frannyjunk
          I am a relative novice when it comes to electronics. I am in the process of fixing a 50” Onn tv. No voltage getting to t-con board (V12, VGH, VCON all reading near zero). On closer inspection, the transistor (on the main board) close to the LDVS socket looks to have blown. I am assuming that replacing this transistor will get the tv going again. Question is, how do I get the transistor part number?
          09-07-2026, 03:41 PM
