HP Z2 SFF G9 Workstation (5F0D1EA) - BIOS corruption fix
  • EpicLPer
    Average Techie
    • Mar 2024
    • 11
    • Austria
    Heya,
    I'm currently trying to fix a “HP Z2 Small Form Factor G9 Workstation (5F0D1EA)” after HP issued a warning that some models may become entirely unbootable if left on specific old versions. The exact issue happened to the one I got right now: https://support.hp.com/us-en/documen...235-8577455-16
    I've already desoldered and dumped the broken BIOS, over on the "level1techs" forums someone already took a look at it and sadly couldn't fix it either 😥 Still grateful of them taking a look however!
    I guess the current BIOS/dump truly seems to be dead. I'm a beginner so not even sure where to start looking but willing to learn 😃
    Later on I would also love to provide an anonymized BIOS dump to everyone who needs and looks for it if possible 😊 This specific model seems to be a bit of a nieche thing as I can't find too much information about it.
    Fault behavior: PC turns on for around 20 seconds, then turns off. No display output, sometimes it restarts automatically but turns off again after 20 seconds. HP recovery is not possible, it doesn't even boot that far 😫 Removing the RAM still shows the typical red blinking LED, so "something" is still working at least 🤣 Trying to turn it on without a BIOS chip at all doesn't even turn the Power LED on, so some functionality is still given by it.
    Board Details:
    SCRABBLE
    REV: A
    M11 FMB-2202
    Model Nr.: 5F0D1EA#ABD
    Ser. Nr.: Please DM if needed, thanks!
    Broken BIOS Dump: Please DM due to dump containing possible personal information, thanks!
    Mainboard
    Chip 1
    Chip 2
    Potential further information
    To my best (yet beginner) knowledge one of them is the BIOS/UEFI chip and the other contains Intel ME data.
    Thanks a lot already for your help! I'm also of course willing to donate a few coffees if this board works again ❤
    Best regards,
    Stefan
    • 20397
    Backup both and post them here in a zip file.
    • EpicLPer
      Average Techie
      • Mar 2024
      • 11
      • Austria
      I don't want to publicly post the dump as it contains the serial number and Windows key, if there's a way to remove those before posting them here I could do so 😅
      However DMing a link to a download is fine to me
        • 20397
        The serial number is required, that`s one of the forum rules - https://www.badcaps.net/forum/troubl...before-posting
        You could blank the serial number using a hex editor, search for hex pattern 01 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 1D 00 00 00
        You could replace it with
        Hex 58 58 58 58 58 2D 58 58 58 58 58 2D 58 58 58 58 58 2D 58 58 58 58 58 2D 58 58 58 58 58
        or
        ASCII XXXXX-XXXXX-XXXXX-XXXXX-XXXXX
        You can edit the windows key back in before flashing the new/fixed bios.
        • EpicLPer
          Average Techie
          • Mar 2024
          • 11
          • Austria
          I think I got the anonymizing down now, can't edit the initial post to add them tho.
          Chip 1: Removed serial number
          Chip 2: Removed Windows Key
          I replaced both instances with the pattern "XYXY".
            • 20397
            Try this one, flash it to chip 2 .Leave chip 1 as-is. See what happens.
            • EpicLPer
              Average Techie
              • Mar 2024
              • 11
              • Austria
              Hi, thanks for the work already ^^ But I think you forgot to attach the BIOS?
                • 20397
                Yes i did
                • EpicLPer
                  Average Techie
                  • Mar 2024
                  • 11
                  • Austria
                  Yes i did
                  Oh my god yes this works almost! There is LIFE!
                  It started up, complained a few times about something not being right and then showed the HP logo screen for a few seconds before restarting. Then it started beeping 4 times slow (red LED) then 2 times fast (white LED). After a hard power cycle it then showed "Critical System Failure", but I think it might be due to something else not being quite right yet with the BIOS or Intel ME.
                  I tried to quickly boot into the BIOS recovery but always ended up on the same critical failure screen, tho I still need to try another keyboard or USB stick potentially and see if that works.
                  If you still have another idea to fix the critical system failure screen I welcome any suggestions But this is BY FAR the furthest I've gotten yet! 👀
                    • 20397
                    Try this new one.
                    • EpicLPer
                      Average Techie
                      • Mar 2024
                      • 11
                      • Austria
                      Try this new one.
                      This one has the same behavior as the one before, it starts up, restarts a few times to recover things, then shows the same replacement board message again. I've also held Win + B the entire time to see if I can enter recovery mode, even while it restored some values, however it never booted into it.
                      So close, I can already smell a success 👀
                      • DynaxSC
                        by DynaxSC
                        11-17-2023, 10:56 AM
                      • grimacelord
                        Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                        by grimacelord
                        This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                        Motherboard model number: DA0PAMB46A1 REV: A
                        Secondary motherboard model number: 0PAB
                        SKU: 685K4UA
                        Serial number is: 5CD3223BJP
                        Recently reflashed this laptop with latest BIOS and once...
                        05-07-2024, 08:06 AM
                      • DynaxSC
                        Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                        by DynaxSC
                        I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                        It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                        I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                        11-06-2022, 05:22 PM
                      • vinaypundith
                        Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
                        by vinaypundith
                        I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
                        So, I'm looking for a BIOS dump for this machine - a 16MB one....
                        08-03-2024, 12:32 PM
                      • hyperwood
                        [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
                        by hyperwood
                        I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
                        The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
                        I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
                        ✅ What I need:
                        • A working 2MB BIOS dump
                        • Matching NM-E471 Rev. 2.0, e.g. JY575
                        06-25-2025, 02:28 PM
