HP Z2 SFF G9 Workstation (5F0D1EA) - BIOS corruption fix
  • EpicLPer
    Average Techie
    • Mar 2024
    • 11
    • Austria
    Heya,
    I'm currently trying to fix a “HP Z2 Small Form Factor G9 Workstation (5F0D1EA)” after HP issued a warning that some models may become entirely unbootable if left on specific old versions. The exact issue happened to the one I got right now: https://support.hp.com/us-en/documen...235-8577455-16
    I've already desoldered and dumped the broken BIOS, over on the "level1techs" forums someone already took a look at it and sadly couldn't fix it either 😥 Still grateful of them taking a look however!
    I guess the current BIOS/dump truly seems to be dead. I'm a beginner so not even sure where to start looking but willing to learn 😃
    Later on I would also love to provide an anonymized BIOS dump to everyone who needs and looks for it if possible 😊 This specific model seems to be a bit of a nieche thing as I can't find too much information about it.
    Fault behavior: PC turns on for around 20 seconds, then turns off. No display output, sometimes it restarts automatically but turns off again after 20 seconds. HP recovery is not possible, it doesn't even boot that far 😫 Removing the RAM still shows the typical red blinking LED, so "something" is still working at least 🤣 Trying to turn it on without a BIOS chip at all doesn't even turn the Power LED on, so some functionality is still given by it.
    Board Details:
    SCRABBLE
    REV: A
    M11 FMB-2202
    Model Nr.: 5F0D1EA#ABD
    Ser. Nr.: Please DM if needed, thanks!
    Broken BIOS Dump: Please DM due to dump containing possible personal information, thanks!
    Mainboard
    Chip 1
    Chip 2
    Potential further information
    To my best (yet beginner) knowledge one of them is the BIOS/UEFI chip and the other contains Intel ME data.
    Thanks a lot already for your help! I'm also of course willing to donate a few coffees if this board works again ❤
    Best regards,
    Stefan
    • 21184
    Backup both and post them here in a zip file.
    • EpicLPer
      Average Techie
      • Mar 2024
      • 11
      • Austria
      I don't want to publicly post the dump as it contains the serial number and Windows key, if there's a way to remove those before posting them here I could do so 😅
      However DMing a link to a download is fine to me
        • 21184
        The serial number is required, that`s one of the forum rules - https://www.badcaps.net/forum/troubl...before-posting
        You could blank the serial number using a hex editor, search for hex pattern 01 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 1D 00 00 00
        You could replace it with
        Hex 58 58 58 58 58 2D 58 58 58 58 58 2D 58 58 58 58 58 2D 58 58 58 58 58 2D 58 58 58 58 58
        or
        ASCII XXXXX-XXXXX-XXXXX-XXXXX-XXXXX
        You can edit the windows key back in before flashing the new/fixed bios.
        • EpicLPer
          Average Techie
          • Mar 2024
          • 11
          • Austria
          I think I got the anonymizing down now, can't edit the initial post to add them tho.
          Chip 1: Removed serial number
          Chip 2: Removed Windows Key
          I replaced both instances with the pattern "XYXY".
            • 21184
            Try this one, flash it to chip 2 .Leave chip 1 as-is. See what happens.
            • EpicLPer
              Average Techie
              • Mar 2024
              • 11
              • Austria
              Hi, thanks for the work already ^^ But I think you forgot to attach the BIOS?
                • 21184
                Yes i did
                • EpicLPer
                  Average Techie
                  • Mar 2024
                  • 11
                  • Austria
                  Yes i did
                  Oh my god yes this works almost! There is LIFE!
                  It started up, complained a few times about something not being right and then showed the HP logo screen for a few seconds before restarting. Then it started beeping 4 times slow (red LED) then 2 times fast (white LED). After a hard power cycle it then showed "Critical System Failure", but I think it might be due to something else not being quite right yet with the BIOS or Intel ME.
                  I tried to quickly boot into the BIOS recovery but always ended up on the same critical failure screen, tho I still need to try another keyboard or USB stick potentially and see if that works.
                  If you still have another idea to fix the critical system failure screen I welcome any suggestions But this is BY FAR the furthest I've gotten yet! 👀
                    • 21184
                    Try this new one.
                    • EpicLPer
                      Average Techie
                      • Mar 2024
                      • 11
                      • Austria
                      Try this new one.
                      This one has the same behavior as the one before, it starts up, restarts a few times to recover things, then shows the same replacement board message again. I've also held Win + B the entire time to see if I can enter recovery mode, even while it restored some values, however it never booted into it.
                      So close, I can already smell a success 👀
                      • Ahari
                        by Ahari
                        I...
                        08-13-2025, 06:12 AM
                      • haitham sharabati
                        [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                        by haitham sharabati
                        Hello engineers 😀,
                        I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                        🔧 Device Info:
                        - Model: HP 15-da2007ne
                        - Product Number: 8XF55EA#ABV
                        - Serial Number: CND0338P0D
                        - CPU: Intel Celeron N4000
                        - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                        💀 Problem:😅
                        - Device shows “Administrator Password”...
                        08-07-2025, 04:54 AM
                      • Citymin
                        by Citymin
                        S/N : 5RNK9FFT70...
                        08-05-2025, 05:12 AM
                      • cozily
                        DELL Precision 3660 Tower Workstation BIOS
                        by cozily
                        I bought a DELL Precision 3660 Tower Workstation from a second-hand seller. After bringing it home, I found out it was actually a testing unit. The BIOS cannot be upgraded (only the ME and PD2 sections are upgradable), and there are test messages displayed during boot, which really affects the user experience.
                        Upon inspecting the motherboard, I noticed that the BIOS is composed of two chips: one 8-pin 16MB chip and one 16-pin 32MB chip.
                        I acquired two new chips from another source containing the official BIOS version, but after installing them, I found that none of the...
                        07-09-2025, 08:43 PM
                      • DynaxSC
                        by DynaxSC
                        11-17-2023, 10:56 AM
