Hp All-in-One PC 24-dp0071nq
  • ledro
    • Aug 2012
    • 49
    • romania
    hello,
    please repaire this bios, black screen only
    HP All-in-One 24-dp0071nq
    SN: 8CC0510DHG
    MB: DAN14DMB6D0 rev D
  • peste
    • 13557
    • ROMANIA
    Originally posted by ledro
    hello,
    SN: 8CC0510DHG
    There is no software or drivers available for your product.
    • mitchw
      HP 14s-fq1010nm Black screen after BIOS update - cannot downgrade
      by mitchw
      Just had a customer bring in a HP 14s-fq1010nm to do some maintenance.
      After updating the BIOS to the latest (F.35) I get black screen (no backlight turning on). However the backlight turns on if I connect an external display to HDMI, but when booting to Windows, both displays remain black.
      After disconnecting internal LCD, and plugging in external display via HDMI, it works on external.
      I tried downgrading it using official method - using an USB drive with older BIOS version, but it fails, saying that the BIOS files are corrupted. I used about 5 different older BIOS versions...
      04-29-2025, 03:45 PM
    • Technodoc
      ASUS G614JZ G634J-PMV-VGT Rog Strix need some bios help, laptop black screen
      by Technodoc
      Asus laptop G614JZ-N3012W Rog Strix with i7
      Mainboard G634J-PMV-VGT
      6050A3441302-MB-A01
      2023-02-10
      Power button works okay....power light goes on
      Red "bottom" leds go on
      Charging led works
      Fans do not spin, capslock key does nothing, screen stays black
      I would like to program the bios again, to rule out a corrupted bios.
      However I run into a size error
      The bios chip is a Winbond 25R256JVEN
      Used my Xgecu T-48 to read the bioschip (using select chip as type XM25QH256B @WSON8, read somewhere...
      02-24-2025, 04:46 AM
    • wizard13
      Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
      by wizard13
      I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
      I have checked the forum and the available documentation but could not find a solution specific to my issue.
      • Brand & Model: Dynabook Satellite Pro C50D-B-100
      • Part Number (P/N): PYU13E-00C00PFR
      • Serial Number (S/N): 22028896H
      • System Configuration (SC): A1PYU13E1127
      • Motherboard Model: IP3_ACN16_MB_V21_20211222A
      • Power Input: DC 19V –
      02-28-2025, 02:43 AM
    • AgustinLorenzo
      [BIOS REQUEST] HP Pavilion 15-BS521TU - Black screen after update BIOS to F.73
      by AgustinLorenzo
      Hi boys,
      This is my first post in BADCAPS and I hope I don't make any mistakes and give the correct explanations.
      Yesterday a friend brought me this laptop home to expand the RAM to 16GB of RAM and update it since it had been abandoned recently.
      Everything was fine, until I made the mistake of updating the BIOS to version F.73 from version F.24, since after according to HP "updating correctly" the laptop never worked again, leaving the screen black but the fan is working and the light of M.2 is on.
      After having carried out all the frequent...
      10-15-2023, 07:31 AM
    • amennone
      Acer A315-24p-r2km , black screen. Bios
      by amennone
      Acer A315-24p-r2km Acer N23C3 snid: 32400005934 s/n NXKDEET00B3240003B3400 Main: IH5JM LA-M611P Rev: 1A
      As per the title, the screen remains black. When the power button is pressed, the blue LED lights up, but the screen is black.
      With an external monitor and HDMI output, there is no image. I loaded the following bins, same situation: ACER_A315_24P_IH5JM_LA_M611P_REV_1A_2022_08_22_WORKING_BIOS_100% IH5JM120.bin from this address https://www.badcaps.net/forum/troubl...a-m611p-rev-1a With the RT 809F programmer, I can't read the contents of the original XMC 25QU128CH1Q SPI, I get the...
      07-31-2025, 04:19 PM
