Please help to fix my Bios Dell Inspiron 3910
  • Tuan Anh Le
    • Oct 2024
    • 8
    • Vietnam
    Hi Guys!
    My Dell Inspiron Dell 3910 has issue that cannot turn on nomarlly! The power led is on (white) but no screen signal and no keyboard signal! It cannot be turn off when press and hold power button! When i take the ram out it has no warning led (keep white)
    So please help to check my bios and fix it if possible!
    the Service Tag is: BK5CQR3
    Thanks very much for your help!
  • hoaca388
    Badcaps
    • Jan 2022
    • 12406
    Originally posted by Tuan Anh Le
    Hi Guys!
    Looks like you have another chip, post it here.
    • Tuan Anh Le
      • Oct 2024
      • 8
      • Vietnam
      Is that the chip that you mention? i cannot import bin file from this chip because my tools only have 8 legs
      Please tell me is there any other way?
      Thanks you so much ​
      • hoaca388
        Badcaps
        • Jan 2022
        • 12406
        Thanks you so much
        Buy a 16 pins.
        • Tuan Anh Le
          • Oct 2024
          • 8
          • Vietnam
          I drain the power of the mainboard (unplug all the power cord and the cmos battery). Now the power light has error code (3 amber 5 white). Can it be repaired by fix the bios or i need to replace the mainboard? I cannot buy the programmer adapter that support 16 pins because in my country its very expensive (almost 100$) (
          Anyway thanks very much for your help!
          • hoaca388
            Badcaps
            • Jan 2022
            • 12406
            https://www.aliexpress.com/w/wholesa...=1745392910312
            • Tuan Anh Le
              • Oct 2024
              • 8
              • Vietnam
              This is my programmer tool but the seller said it will not work with the 16pins clip
              • danito
                • Jun 2016
                • 1151
                • Romania
                SOP16 to DIP8
                • zenius
                  by zenius
                  12-08-2024, 06:13 AM
                • danielgagcia
                  Bios inspiron p69g dell inspiron starlord13 b 152641 stuck in dell logo
                  by danielgagcia
                  Hi i need this bios it stuck in dell logo can help me
                  MB: starlord13 b 152641
                  SN: 5F50ZB2...
                  Yesterday, 05:25 PM
                • sahamipoor
                  need bios dell Inspiron 17 7000 2-in-1 p42e
                  by sahamipoor
                  hi...
                  i need bios of dell Inspiron 17 7000 2-in-1 p42e by chassis Jedi 15/17 cml-mb 18806-1.no display by bios issue.
                  i used and flashed ( dell Inspiron 17 7591) by same chassis and worked .but TMP not detect showing. and not enabling in bios(after each reset disable again). Most importantly the booting up display and startup bios (before windows loading) is too many slow!
                  i updated to latest version and try other version but not working!
                  service tag: HCQ3JW2
                  i need your kind....
                  10-01-2025, 11:10 AM
                • zlr8r
                  looking for fully extracted by programmer Bios for a Dell Inspiron 17 (7786)
                  by zlr8r
                  looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
                  cheers
                  Dell Inspiron 17 (7786) Laptop
                  Service Tag: 5J0NHT2
                  Bios: 1.9.0
                  MOBO: RO 15 17 WHL 2GB MB / 18706-2
                  Attached;
                  1. My saved bios using a programmer
                  2. Dells Bios updater .exe (v1.16)
                  3. Dells Bios recovery file
                  4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
                  5. Image of ME...
                  12-18-2023, 03:08 PM
                • mikeybass
                  by mikeybass
                  04-23-2025, 04:30 PM
