M920x Desktop (ThinkCentre) - Type 10S1 bios
  • evil_santa
    Hey there
    I bought a p330 Mainboard with (probably) broken bios.
    PC starts automatically after connecting power, solid green and red led (iluminates logo),
    Fan spins and no beeps.
    Please check bios
    Lenovo P330
    Board EQ370 NM-B551 iq3x0il REV 1.0
    and i cant find a serial number on the Mainboard​ only a long barcode and the mac address as small stickers
    donation is in the way for this great forum
    • 21853
    Moved to a new thread. The serial number in your bios is PC13FQNG . Model: M920x Desktop (ThinkCentre) - Type 10S1
    • volinakis
      • Jan 2021
      • 2874
      • N/A
      Originally posted by evil_santa
      Hey there
      Please check bios
      Lenovo P330
      try image extracted from update and clean ME. I don't know where DMI is, maybe SMDFlea can help you with that.
        • 21853
        The serial,model and model type can be added using the bios updater. Input "y" instead of "n"
        https://download.lenovo.com/pccbbs/t...m1ujy77usa.txt
        6. You will see the prompt "Would you like to update the Serial
        Number?". Input "n" and press Enter.
        7. Then you will see the prompt "Would you like to update the
        Machine Type and Model?". Input "n" and press Enter again.
        Then the BIOS update process will start.
        I don`t know if the OA3 key can be added using the updater, there might be some hidden command that isn`t listed ? . It can be added using UEFITool or a hex editor. I`ve added the key in 2 places, C05140 - C05190 and C55402 - C55452
        Click image for larger version  Name:	Capture.jpg Views:	0 Size:	210.8 KB ID:	3465111
        If it doesn`t work then the next thing i would try would be copying the NVRAM GUID CEF5B9A3-476D-497F-9FDC-E98143E0422C
        • hotcrossedbuns999
          M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
          by hotcrossedbuns999
          My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
          1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
          2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
          3. I could only locate two chips that look like bios chips. Could someone verify this
          01-03-2025, 12:32 PM
        • macabook
          by macabook
          🧩 Initial Issue
          07-24-2025, 02:17 PM
        • grimacelord
          by grimacelord
          Hello there.
          History:
          03-15-2023, 03:29 PM
        • AustinCER
          HP ENVY Desktop TE01-1214 - No Display, Powers On, Corrupt BIOS
          by AustinCER
          I currently have an HP ENVY Desktop TE01-1214
          S/N -
          2MO22342GX
          Motherboard - L75365-001
          BIOS Chip - W25Q128JVSQ
          Suspected Windows updates contained BIOS update in which, during update the Desktop PC displayed a black screen to the monitor while still powered on. Display image never restored.
          Tested RAM in both slots, as well as new RAM. Tested a brand new known working i5-10th Gen GPU (Same CPU as original installed). Cleared CMOS. Tested the Desktop PC with a dedicated GPU connected, but still no display. Device will not POST when powered...
          04-25-2025, 05:56 PM
        • pirati
          by pirati
          Today, 04:20 PM
