DELL IPKBL-SM 5250 AIO
  • SomnusDisney013
    • Oct 2022
    • 18
    • Poland
    Good morning,
    I have a problem with the BIOS of the DELL 5250. I have a LAN error in Windows. Is anyone able to fix this? I don't know if MEregion wasn't cleaned. SN:H2P3MM2
  • SomnusDisney013
    • Oct 2022
    • 18
    • Poland
    If someone doesn't clean me region. Maybe it has a working BIOS itself?
    • hoaca388
      Badcaps
      • Jan 2022
      • 11853
      Originally posted by SomnusDisney013
      Good morning,
      OptiPlex 5250 All-In-One
      Service Tag: H2P3MM2
      • SomnusDisney013
        • Oct 2022
        • 18
        • Poland
        Good day, unfortunately I was sick. BIOS works fine but I got an error in device manager. Intel Ethernet Connection(5) I219-V
        error 10. Why does LAN not work. I know it has to do with BIOS but I can't fix it myself. I tried another BIOS where there is China HDD Protection and Lan works but no TPM.​
          • 21081
          There should be a sticker on the motherboard with the MAC address on it. Post it
          • SomnusDisney013
            • Oct 2022
            • 18
            • Poland
            This is the only thing apart from the service tag sticker.
            • Bowline
              by Bowline
              06-11-2025, 10:13 AM
            • master3112
              by master3112
              07-29-2025, 01:55 PM
            • F R 2568
              Dell Latitude 5420 does not start (no post) need help to find the reason why
              by F R 2568
              Hello all,
              this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
              I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
              If the laptop is only connected to the AC adapter (battery removed):
              When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
              The power/battery...
              01-08-2025, 05:45 AM
            • diamon
              Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
              by diamon
              I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
              Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
              Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
              Pictures of these boards:
              Dell Latitude 5520 https://www.ebay.com/itm/256052956663
              Dell Latitude 5530 https://www.ebay.com/itm/125844181534
              Dell...
              02-28-2024, 12:51 PM
            • lalle-
              Dell G5 SE 5505 - "Invalid memory installed" after BIOS update.
              by lalle-
              Hello!
              I have a problem with a Dell G5 SE 5505 laptop that I hope someone can give me a few pointers on.
              [OK, it's not really a laptop, I'm running the motherboard on my desktop with only cooling, RAM and an M2 drive attached.]
              I had some performance issues, so I decided to update my BIOS from 1.7.0 to the latest version, 1.20.0.
              The computer restarted and the update dit not want to continue without a battery connected, even though I used dell's method of bypassing this requirement.
              I tried updating to a custom BIOS from Reddit user Satori_Nori https://www...
              08-11-2024, 02:01 PM
