DELL IPKBL-SM 5250 AIO
  • SomnusDisney013
    • Oct 2022
    • 19
    • Poland
    Good morning,
    I have a problem with the BIOS of the DELL 5250. I have a LAN error in Windows. Is anyone able to fix this? I don't know if MEregion wasn't cleaned. SN:H2P3MM2
  • SomnusDisney013
    • Oct 2022
    • 19
    • Poland
    If someone doesn't clean me region. Maybe it has a working BIOS itself?
    • hoaca388
      Badcaps
      • Jan 2022
      • 12269
      Originally posted by SomnusDisney013
      Good morning,
      OptiPlex 5250 All-In-One
      Service Tag: H2P3MM2
      • SomnusDisney013
        • Oct 2022
        • 19
        • Poland
        Good day, unfortunately I was sick. BIOS works fine but I got an error in device manager. Intel Ethernet Connection(5) I219-V
        error 10. Why does LAN not work. I know it has to do with BIOS but I can't fix it myself. I tried another BIOS where there is China HDD Protection and Lan works but no TPM.​
          • 21679
          There should be a sticker on the motherboard with the MAC address on it. Post it
          • SomnusDisney013
            • Oct 2022
            • 19
            • Poland
            This is the only thing apart from the service tag sticker.
            • Bowline
              by Bowline
              06-11-2025, 10:13 AM
            • Akhlz001
              by Akhlz001
              09-20-2025, 07:15 PM
            • master3112
              by master3112
              07-29-2025, 01:55 PM
              Dell Thunderbolt Firmware
              by SMDFlea
              Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
              Some models have a choice of 2 different firmwares, it depends on the dell SKU.
              The SKU is in brackets (****)
              EDIT: NVM65...
              01-26-2025, 06:22 AM
            • F R 2568
              Dell Latitude 5420 does not start (no post) need help to find the reason why
              by F R 2568
              Hello all,
              this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
              I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
              If the laptop is only connected to the AC adapter (battery removed):
              When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
              The power/battery...
              01-08-2025, 05:45 AM
