HP 400 G9 MINI bios
  • smallvhin
    • Jul 2015
    • 192
    • philippines
    #41
    Master help to remove password and clean EC file
    more thanks master
    SN: 8CC4111BJQ
    • gsm_code
      • Oct 2023
      • 55
      • philippines
      #42
      more thanks master
      SN: 8CC4111BJQ
      Try giv feedback😊
      • smallvhin
        • Jul 2015
        • 192
        • philippines
        #43
        Originally posted by gsm_code
        Try giv feedback😊
        no luck master same issue.
        • beriwa
          • Jul 2025
          Hi, master
          Please you can help me, i need remove the bios password.
          HP Pro Mini 400 G9
          SN: 8CC4222B3C
          THANKS A LOT
          • peste
            • Dec 2016
            • 13827
            • ROMANIA
            #45
            Originally posted by beriwa
            Hi, master
            HP Pro Mini 400 G9
            SN: 8CC4222B3C
            THANKS A LOT
            post the original contents of the bios chip..
            • anceng
              • Nov 2020
              • 21
              • Philippines
              #46
              Hello Masters,
              please help to remove bios password and computrace if there is one.
              Main Bios and EC are uploaded.
              HP Pro Mini 400 G9
              SN: 8CC42520Z4
              might replace Nuvoton NPCD321HA0DX also.
              Thank you Masters! Have a prosperous day!
              • gsm_code
                • Oct 2023
                • 55
                • philippines
                #47
                Originally posted by anceng
                Hello Masters,
                HP Pro Mini 400 G9
                SN: 8CC42520Z4
                Try giv feedback
                • eXec0101
                  • Mar 2016
                  • Kosovo
                  #48
                  Please help me with Master Password
                  SN: 8CC4213RQ6
                  SKU: 937T9EA#ABD
                  System Board ID: 8C63
                  CT Number: PTEXP0C8JJK38E
                  • peste
                    • Dec 2016
                    • 13827
                    • ROMANIA
                    #49
                    SN: 8CC4213RQ6
                    SKU: 937T9EA#ABD
                    • zenius
                      by zenius
                      12-08-2024, 06:13 AM
                    • berrylinx
                      Dell Latitude 7400 2-in-1 bios with absolute persistence lock
                      by berrylinx
                      Dell Latitude 7400 2-in-1 bios with absolute persistence lock, Service Tag: HRPJN53
                      Can someone please assist with this please. I've provided two dump files using Xgeco T48, one is the read and default saved and other is the Flash saved option, they're labeled according.
                      Thank You....
                      09-15-2025, 03:02 PM
                    • macabook
                      by macabook
                      🧩 Initial Issue
                      07-24-2025, 02:17 PM
                    • cr4zychriss
                      by cr4zychriss
                      • Rebrand: PC Specialist
                      11-14-2025, 04:04 PM
                    • Akhlz001
                      by Akhlz001
                      09-20-2025, 07:15 PM
