Asrock A520M-HDV
  • nicohd87
    • Mar 2020
    • 10
    • Argentina
    Asrock A520M-HDV
    Hello, I need help please. I have an Asrock a520m-hdv mother that after updating the bios it doesn't boot anymore. I tried to program with the latest and first version of the official website and it remains the same. I searched the web for a dump and couldn't find it. I leave you the original bios that does not boot after the update. Thank you very much from Argentina.
    PS: If you can tell me what program you use to repair .bin, I would also appreciate it​
  • leo037_2023
    DEMIGOD OF BIOS
    • Oct 2023
    • 63
    • Buenos Aires - Argentina
    hola ahi te dejo el bios probalo y comenta como te fue.
    Hello, here I leave you the bios, try it and tell me how it went if it worked for you.
    • sector152
      • Dec 2024
      • Poland
      I don't know about nicohd87, but your bios worked for me. The manufacturer's bios also failed for me.
      Thank you leo. Cheers to you.
      • throwaway327
        by throwaway327
        Model No: RC72LA
        Serial No: SBNVKD001014459
        06-18-2025, 05:52 PM
      • Grucha98
        Asrock Fatal1ty B450 Gaming-ITX/ac wont boot, cpu phases turn off after a few seconds. Bios?
        by Grucha98
        Hi I'm working on that asrock motherboard. It had shoted mosfet on cpu phase(changed) and 1 cap on bottom side(changed). Led driver is probably shotted too because voltage on one leg of this chip is 0.5v to 5v (its in loop rising and falling) its's RT7905 and i cant find datasheet :/ But its only led driver so mb should work without it. When i desolder it on the same leg is 5v all the time.
        If i start mb on all cpu phases is 1v1 for a few seconds only. Other voltage are present. So i tried to flash bios with the newest on official site and it doesnt help. Its not normal extension...
        01-19-2025, 03:40 PM
      • q2v5
        Lenovo T480s, what's up with this Bios, modded boot logo, reflashed now bricked
        by q2v5
        Lenovo T480s
        Model 20L8-S3TE00
        Board ET481-U10
        Chip MX25L12873F
        Hi, I have a few of these & they came with a custom bios boot logo, no passwords etc.
        2 x were brand new unused but with custom boot logo, 1 I installed Windows/ran updates then it bricked itself. 1 wouldn't get past the custom bios boot logo.
        The third I loaded windows, took a backup of the bios chip, then tried to flash several different clean bios's via programmer which all caused it to not boot. I tried to reflash the original bios both using clip & desoldering but...
        08-15-2024, 10:40 PM
      • Neddsme
        Bios partially corrupted somehow and now warm boot doesn't work which is critical
        by Neddsme
        Hie.
        I own a Lenovo ideapad v310-15IKB with an i5 7th generation with only Intel graphics configuration.
        Now the heart of the problem is that I don't know when or how it happened but I suddenly started getting distortion in the graphics output on the LCD. This basically meant a black screen full of flickering multicolored short horizontal lines. This would happen 30-60 minutes after booting and using it normally.
        I run Windows 10 20H build so I thought it was just a Windows update issue or graphics driver outdated issue.
        I managed to run Windows troubleshooting and...
        02-04-2022, 05:57 AM
      • Max029
        Lenovo LOQ mdl 151RH8 bios Q: Can't get usb boot to list
        by Max029
        I've searched and read Beginners guidelines and other sticky threads. This is just a simple bios question. If I may, I'm having trouble finding any help, including from lenovo tech support & forum, for how to get usb boot to list in boot options. I'm trying to run memtest86 so nothing as highfaluting as re-install, flash a bios, etc.
        I've made usb boot enabled and secure boot is disabled. I can find no other option in bios ver LZCN34WW (the original bios). Would anyone here be familiar with LOQ or Legion bios versions & know what is going on?
        TY,
        08-18-2024, 08:28 PM
