Lenovo ideacentre 310s-08asr bios problem
  • MikeBaxter
    • May 2020
    • 28
    • IT
    Hi, i read more guide to extract the bios bin from the installer...but nothing.
    i use the innoextractor but with errors:
    Not a supported Inno Setup installer!
    Done with 1 error.
    i download the installer (o2hjy63usa.exe) directly from lenovo support with the PC serial number:
    https://support.lenovo.com/it/it/dow...tre-310s-08asr
    the flash on the mobo is a MX25U6435F.
    my question is how can i extract the bios??
    thanks a lot for your help
  • hoaca388
    Badcaps
    • Jan 2022
    • 11784
    Done with 1 error.​
    Use 7zip.
    • MikeBaxter
      • May 2020
      • 28
      • IT
      Okay, I tried to extract files directly from the installer using 7zip, but I get many large 64Mbit files. When I try to compare them with each other using a hex editor like Neo, they are all different from each other. So, which one should I use? The files are of the following types:
      • IMAGEO2H.rom
      • O2H3X.rom
      • 310/O2H3X
      • 310/O2H3X.rom
      All are 8192kbytes in size (i.e., 64Mbit), but none are file.bin.
      • hoaca388
        Badcaps
        • Jan 2022
        • 11784
        • IMAGEO2H.rom
        • O2H3X.rom
        • 310/O2H3X
        • 310/O2H3X.rom
        There are 2 files: IMAGEO2H.rom and O2H3X.rom equivalent to two bios.
        Do you have experience building bios?
        • MikeBaxter
          • May 2020
          • 28
          • IT
          no 😅
          all time i download the firmware and i flash it
          • hoaca388
            Badcaps
            • Jan 2022
            • 11784
            no 😅
            This is an incomplete bios. Before doing this, you must backup the bios and always remember to back up the bios successfully.
            • MikeBaxter
              • May 2020
              • 28
              • IT
              i haven't a backup, because the pc don't start, infact i want to program the flash directly with a CH341a (with 1.8V mod).
              but, this is how i read from the flash
              • hoaca388
                Badcaps
                • Jan 2022
                • 11784
                https://www.badcaps.net/forum/troubl...21#post1622421
                https://www.badcaps.net/forum/troubl...matic-requests
                • MikeBaxter
                  • May 2020
                  • 28
                  • IT
                  Ok, so from my dump you say it corrupted?
                  When I try to write the flash, I have all time an error on 0x00020040, so I cancel the flash 4-5 and I try again to write IMAGEO2H.rom...success.
                  Thanks for your help.
                  PS before to open this thread I search and search for a solution 😅
                  • MikeBaxter
                    • May 2020
                    • 28
                    • IT
                    Scuse me but i can't find a guide to make a new bios from my old dump.
                    • MikeBaxter
                      • May 2020
                      • 28
                      • IT
                      Someone can give me a concrete help to make a new bios from my old dump? thanks
                      I can't find a guide for a mobo like mine.
                      thanls
                        • 20966
                        bios
                        • MikeBaxter
                          • May 2020
                          • 28
                          • IT
                          thanks friend, I flashed the bios as you attached it but nothing to do, it doesn't work.
                          Monitor always black and if I try to remove the RAM the buzzer doesn't beep
                          • Wahaz
                            by Wahaz
                            10-30-2023, 08:42 PM
                          • survivalbloke
                            Unable to extract Lenovo BIOS file from installer
                            by survivalbloke
                            I'm working on a Lenovo LOQ 15APH8, Serial# MP2L9MAV. I want to flash a new BIOS onto it, but I'm also trying to learn this process for my own enrichment and professional development.
                            I was watching some tutorials, copying the serial info blocks from the old bios to a new bios. Before that though, they use innoextract on the Lenovo .exe. I downloaded Innoextract v1.9 but it tells me my .exe is not a supported inno setup installer(see screenshot). So if I unpack this using 7zip, I do get a .ROM file, but according to my tutorials, I'm looking for a .FD file.
                            How can...
                            07-16-2025, 03:21 PM
                          • grimacelord
                            Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                            by grimacelord
                            Hello there.
                            I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                            History:
                            1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                            I searched for this error online and discovered...
                            03-15-2023, 03:29 PM
                          • bursauzman
                            Lenovo ideacentre 5 14ACN6 Bios
                            by bursauzman
                            Hello.
                            No display.
                            Can you clear the BIOS?
                            I NEED WORKING BIOS
                            Product Family: Lenovo ideacentre 5 14ACN6
                            Machine Type: 90RX
                            SN: PC25EZJ5...
                            07-07-2025, 05:10 AM
                          • jendkkd jeje
                            Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                            by jendkkd jeje
                            So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                            I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                            10-11-2024, 03:12 PM
