Lenovo ideacentre 310s-08asr bios problem
  • MikeBaxter
    • May 2020
    • 28
    • IT
    Hi, i read more guide to extract the bios bin from the installer...but nothing.
    i use the innoextractor but with errors:
    Not a supported Inno Setup installer!
    Done with 1 error.
    i download the installer (o2hjy63usa.exe) directly from lenovo support with the PC serial number:
    https://support.lenovo.com/it/it/dow...tre-310s-08asr
    the flash on the mobo is a MX25U6435F.
    my question is how can i extract the bios??
    thanks a lot for your help
  • hoaca388
    Badcaps
    • Jan 2022
    • 12403
    Done with 1 error.​
    Use 7zip.
    • MikeBaxter
      • May 2020
      • 28
      • IT
      Okay, I tried to extract files directly from the installer using 7zip, but I get many large 64Mbit files. When I try to compare them with each other using a hex editor like Neo, they are all different from each other. So, which one should I use? The files are of the following types:
      • IMAGEO2H.rom
      • O2H3X.rom
      • 310/O2H3X
      • 310/O2H3X.rom
      All are 8192kbytes in size (i.e., 64Mbit), but none are file.bin.
      • hoaca388
        Badcaps
        • Jan 2022
        • 12403
        • IMAGEO2H.rom
        • O2H3X.rom
        • 310/O2H3X
        • 310/O2H3X.rom
        There are 2 files: IMAGEO2H.rom and O2H3X.rom equivalent to two bios.
        Do you have experience building bios?
        • MikeBaxter
          • May 2020
          • 28
          • IT
          no 😅
          all time i download the firmware and i flash it
          • hoaca388
            Badcaps
            • Jan 2022
            • 12403
            no 😅
            This is an incomplete bios. Before doing this, you must backup the bios and always remember to back up the bios successfully.
            • MikeBaxter
              • May 2020
              • 28
              • IT
              i haven't a backup, because the pc don't start, infact i want to program the flash directly with a CH341a (with 1.8V mod).
              but, this is how i read from the flash
              • hoaca388
                Badcaps
                • Jan 2022
                • 12403
                https://www.badcaps.net/forum/troubl...21#post1622421
                https://www.badcaps.net/forum/troubl...matic-requests
                • MikeBaxter
                  • May 2020
                  • 28
                  • IT
                  Ok, so from my dump you say it corrupted?
                  When I try to write the flash, I have all time an error on 0x00020040, so I cancel the flash 4-5 and I try again to write IMAGEO2H.rom...success.
                  Thanks for your help.
                  PS before to open this thread I search and search for a solution 😅
                  • MikeBaxter
                    • May 2020
                    • 28
                    • IT
                    Scuse me but i can't find a guide to make a new bios from my old dump.
                    • MikeBaxter
                      • May 2020
                      • 28
                      • IT
                      Someone can give me a concrete help to make a new bios from my old dump? thanks
                      I can't find a guide for a mobo like mine.
                      thanls
                        • 22084
                        bios
                        • MikeBaxter
                          • May 2020
                          • 28
                          • IT
                          thanks friend, I flashed the bios as you attached it but nothing to do, it doesn't work.
                          Monitor always black and if I try to remove the RAM the buzzer doesn't beep
                          • lucaszmn
                            by lucaszmn
                            Problem:
                            Initial Findings:
                            • I concluded that the
                            08-12-2025, 03:01 PM
                          • max_sneka2
                            Lenovo Ideacentre AIO 24IHR9 Bios needed
                            by max_sneka2
                            Good Evening
                            Lenovo AIO Ideacentre 24IHR9
                            Working but no display
                            Bios Issue
                            Board Number JOC10 LA-N241P IRPLSC1 REV 1.0
                            S.N MP2G2K47
                            Machine Type F0HN
                            MTM F0HN00AJAK
                            MO MPNXS481301Y...
                            10-16-2025, 11:45 AM
                          • Wahaz
                            by Wahaz
                            10-30-2023, 08:42 PM
                          • survivalbloke
                            Unable to extract Lenovo BIOS file from installer
                            by survivalbloke
                            I'm working on a Lenovo LOQ 15APH8, Serial# MP2L9MAV. I want to flash a new BIOS onto it, but I'm also trying to learn this process for my own enrichment and professional development.
                            I was watching some tutorials, copying the serial info blocks from the old bios to a new bios. Before that though, they use innoextract on the Lenovo .exe. I downloaded Innoextract v1.9 but it tells me my .exe is not a supported inno setup installer(see screenshot). So if I unpack this using 7zip, I do get a .ROM file, but according to my tutorials, I'm looking for a .FD file.
                            How can...
                            07-16-2025, 03:21 PM
                          • grimacelord
                            by grimacelord
                            Hello there.
                            History:
                            03-15-2023, 03:29 PM
