Hp Elite Mini 800 G9 Bios Password
  • witcher79
    • Sep 2021
    • 6
    Hello
    Can anyone remove the bios password from the Hp Elite Mini 800 g9. I am attaching the bios password file. Thank You
  • volinakis
    • Jan 2021
    • 2733
    • N/A
    Re: Hp Elite Mini 800 G9 Bios Password
    Originally posted by witcher79
    Hello
    At 1st boot press F10 and reset bios to factory defaults, save, restart and password will go on. After that enter in bios setup and in Main tab you have "set machine unique data" and write there what it's written on the label inside the bottom cover. Or extract DMI from your bios dump:
    Feature Byte: 3E476J6S6b7B7H7M7Q7T7W7maBapaqaucAdpdqeMfPgugzhKhZjhk8mEmVn7nVngnupDpVpq.43 (no spaces)
    Serial: 8CC24122ZP
    SKU: 5X7H6EA#ABU
    Build ID: 22WWQ6AT602#SABU#DABU
    Board CT: PQYXK0B8JH8GJN
    Name: HP Elite Mini 800 G9
    Save and use BCU to exit MPM mode or restart laptop how many times counter shows.
    • witcher79
      • Sep 2021
      • 6
      There is still a password for the bios after uploading your bios file
      • witcher79
        • Sep 2021
        • 6
        Can anyone help with this model?
        • volinakis
          • Jan 2021
          • 2733
          • N/A
          1st thing TO DO is to RESET BIOS TO FACTORY DEFAULT! DID I STUTTER?
          • witcher79
            • Sep 2021
            • 6
            When I press F10 it asks for the password as before I cannot enter the bios for Reset to factory settings.
            • volinakis
              • Jan 2021
              • 2733
              • N/A
              did you remove CMOS battery?
              • witcher79
                • Sep 2021
                • 6
                Before yes, but when uploaded your bios I put it in before switched it on. Should reprogram the bios again and switch it on without cmos battery? Thanks
                • volinakis
                  • Jan 2021
                  • 2733
                  • N/A
                  of course, it's basics! no power source should be connected.
                  • witcher79
                    • Sep 2021
                    • 6
                    Is the same and the password is still there. This message appears on first start-up
                    The bios has recovered its identity data from the Embedded Controller due to hash mismatch
                    • volinakis
                      • Jan 2021
                      • 2733
                      • N/A
                      so you have another eeprom chipset for EC, upload it here.
                      • witcher79
                        • Sep 2021
                        • 6
                        This is what I found on the board to check. Thanks
                        • witcher79
                          • Sep 2021
                          • 6
                          Does anyone know how to remove the password or is good only to parts?
                          • pcrepai
                            • Jul 2021
                            • 46
                            • Nederland
                            HP ELITE MINI 800 G9 bios password (F96A MBQ-2201)
                            Hi, I received desktop HP with password in bios how can I remove it, or can anyone remove it for me ? oryg dump in attachment.
                              • 20952
                              Re: HP ELITE MINI 800 G9 bios password (F96A MBQ-2201)
                              You MUST post the PC serial number, please read the updated rules !
                              https://www.badcaps.net/forum/showthread.php?t=103569
                              • rex98
                                • Feb 2023
                                • 1278
                                • Mandaue CEBU, Philippines
                                upload your EC dump here. its 16mb also post your serial
                                • pcrepai
                                  • Jul 2021
                                  • 46
                                  • Nederland
                                  SN:8CC3122SZ4
                                  I found second chip which is also 32mb (photo) but Im not sure if its EC
                                  Regards
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 11750
                                    SN:8CC3122SZ4
                                    Regards
                                    Unlock
                                    • pcrepai
                                      • Jul 2021
                                      • 46
                                      • Nederland
                                      Originally posted by hoaca388
                                      Unlock
                                      Ive tried this file, but bios goes directly in recovering previos version, so I still have a password
                                      • meanaverage
                                        • Nov 2023
                                        • 3
                                        • US
                                        SN:8CC3122SZ4
                                        Regards
                                        Can you confirm this is the correct chip to read from? Have a couple HP 600 G9 Minis and trying to confirm.
                                        • volinakis
                                          HP Elite Mini 600 G9 Desktop PC Bios Password
                                          by volinakis
                                          Hi, I need help to remove bios password please.
                                          Name: HP Elite Mini 600 G9 Desktop PC
                                          S/N: 8CC4131WJ8
                                          Prod Id: 4C5J7AV
                                          I did usual modifications to enter in MPM mode but with modifications it restarts several times then when it boots it appears message: "Bios Identity Data Recovered The BIOS has recovered its identity data from the Embedded Controller due to data mismatch" and did not enter in MPM mode.
                                          I attach main and EC backups, maybe Badcaps Masters can help me, thank you in advance.
                                          post moved......
                                          09-10-2024, 12:34 PM
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • traxformania
                                          TONGFANG "GM7TG7P" Bios Password Problem?
                                          by traxformania
                                          I tried :
                                          -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                          11-15-2023, 07:32 AM
                                        • tlindi
                                          Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                                          by tlindi
                                          Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                                          Ack
                                          Ack
                                          01-30-2025, 04:26 AM
                                        • Nopslide
                                          by Nopslide
                                          04-01-2024, 04:27 PM
