Bios Bin Asus Prime H310M-D R2.0
  • Higuain rori
    • Mar 2023
    • 12
    • Indonesi
    i need Bios Bin Asus Prime H310M-D R2.0 Please...
  • peste
    • Dec 2016
    • 13573
    • ROMANIA
    Re: Bios Bin Asus Prime H310M-D R2.0
    post the original bios even if it is corrupted..
    • Higuain rori
      • Mar 2023
      • 12
      • Indonesi
      this file bios backup corupt
      • hoaca388
        Badcaps
        • Jan 2022
        • 12328
        ssssss
        • esboo143
          • Sep 2023
          • Philippines
          tnx sir
          • razor_amd
            by razor_amd
            12-15-2020, 07:07 PM
          • pirati
            by pirati
            Yesterday, 04:20 PM
          • grimacelord
            by grimacelord
            07-10-2025, 02:52 PM
          • DynaxSC
            by DynaxSC
            06-14-2024, 03:49 PM
          • oragano
            ASUS ex-b250-V7 motherboard bios corrupted - by me
            by oragano
            hey all, i did a silly thing and flashed bios to perfectly working board. None of the asus official download bios would work with ez flash. They all gave error saying not supported bios file. I tried using uefi tool to extract it to a bin file but then ez flash wouldnt even recognise it.
            So, i used freedos and afudos with the aforementioned bin file i extracted and forced the issue. After bios reprogram, reboot and it was dead. Fans spinning but no post.
            i have a bios writer and none of the .cap files from the official site work either. I just get one spin, then off, then all fans...
            10-17-2024, 02:53 AM
