Bios Bin Asus Prime H310M-D R2.0
  • Higuain rori
    • Mar 2023
    • 12
    • Indonesi
    i need Bios Bin Asus Prime H310M-D R2.0 Please...
  • peste
    • 12812
    • ROMANIA
    Re: Bios Bin Asus Prime H310M-D R2.0
    post the original bios even if it is corrupted..
    • Higuain rori
      • Mar 2023
      • 12
      • Indonesi
      this file bios backup corupt
      • hoaca388
        Badcaps
        • Jan 2022
        • 11736
        ssssss
        • esboo143
          • Sep 2023
          • Philippines
          tnx sir
          • razor_amd
            by razor_amd
            12-15-2020, 07:07 PM
          • grimacelord
            by grimacelord
            07-10-2025, 02:52 PM
          • throwaway327
            by throwaway327
            Model No: RC72LA
            Serial No: SBNVKD001014459
            06-18-2025, 05:52 PM
          • Pedro Ramírez
            Corrupted BIOS on Asus Prime H510M-E R1.00
            by Pedro Ramírez
            Hello, my computer lost its image due to a problem with the graphics card (it was shorted out). Now the computer only turns on the fans but I have no image. Could you please help me with the BIOS? I've attached a backup....
            07-21-2025, 08:34 PM
          • DynaxSC
            by DynaxSC
            06-14-2024, 03:49 PM
