I want a solution to the problem biostar A320MH ver 6.0 bios
  • hamada2h
    • Nov 2018
    • 7
    • egypt
  • R_J
    • 9608
    Re: I want a solution to the problem
    What version of ch341a software? some newer versions seem to have this problem. I ran into this problem with version V1.29 and V.130. V1.18 worked without the error
    • petehall347
      • Jan 2015
      • 4442
      • United Kingdom
      some sort of argument going on .
      this is best i can find ..hope it helps ..
      https://notebookreparos-com-br.trans...n&_x_tr_pto=sc
      • hamada2h
        • Nov 2018
        • 7
        • egypt
        The problem recurred with older versions
        • lucaszmn
          by lucaszmn
          Problem:
          Initial Findings:
          • I concluded that the
          08-12-2025, 03:01 PM
        • AquaMan Ua
          by AquaMan Ua
          05-17-2025, 09:40 AM
        • traxformania
          TONGFANG "GM7TG7P" Bios Password Problem?
          by traxformania
          I tried :
          -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
          11-15-2023, 07:32 AM
        • macabook
          by macabook
          🧩 Initial Issue
          07-24-2025, 02:17 PM
        • trouble55
          NEC VersaPro PC-VRT42FBFR22B BIOS problem
          by trouble55
          Hi All,
          [Mother board model]
          V-VE212(U3E1)
          [Serial number]
          24000135PA
          [BIOS chip model]
          Macronix MX77L12850F
          I am having some problems with the BIOS of my Versapro PC-VRT42FBFR22B.
          I extracted the BIOS file (versapro001.bin 16MB) from PC-VRT42FBFR22B ROM (MX77L12850F) using CH341A and NeoProgrammer V2.2.0.10, but I don't know how to remove the BIOS password, so I can't open the BIOS even if I boot with F2.
          I also downloaded the BIOS update package (933A0400.zip) for PC-VRT42FBFR22B from the official...
          09-19-2024, 01:24 AM
