BIOS for Dell optiplex 7080 micro
    Ok. So I did a diff on previous submitted and unlocked files and found the edits that were made. Edited my own file, re-flashed and it works :-) Thanks for the info.
      Hi All.
      So i got a free Little Dell Micro That I want to put linux on to further learn on, however, its Bios Locked with the 8FC8, and I need to change some settings on it.
      Ive been reading this forum, and it looks like this bios can be patched, but in order to do so, i would need a dump of my existing bios, which i dont have. I dont have the equipment to do so either at this time. I wasnt sure if someone had a Bios I could use for this? Im a little confused on how this
      actually works. But im learning!
      Dell micro Optiplex 7080
      Service Tag: 5H9N8B3
      8FC8 Bios lock.
      Need either original bios or patched? Thank you!
        Just an update.
        Im a moron, I was thinking the Bios could be flashed with software if someone uploaded. but looks like it would need to have a programmer to flash it, which i dont currently have.
        Nevermind then! Thanks anyways
          SMDFlea commented
          Editing a comment
          Thread merged with 7080 micro topic.
        90skidjohnny hi i undesrtand your situation, but try with this password = gggggngn and feedback me.
        write this password gggggngn and tell me if work for you -.
          Thanks for the reply! I did try that one as well , but unfortunately didn't work.
            Hey everyone,
            I see a lot of people here sharing their BIOS backups to get unlocked, and I'd like to do the same with my Dell Optiplex 7080 Micro. Can anyone explain how to back up the BIOS properly?
            Thanks a lot for the help
              Finally, I did some research, and it seems I need a programmer to back up my BIOS. The BIOS chip is MX25L25673GHI with 16 pins. I'm not sure which exact programmer and clip I should buy. Can anyone recommend a reliable setup that works well for this chip? And, is it possible to back up the bios just by using Windows OS on the computer directly, because i see various app such as Universal BIOS Backup Toolkit that looks fine. Thanks for your help
                see what programmer your bios chip supports..
                  Tell me where I can get the bios when the firmware is damaged, there is no dumpa, I need a new one. sertag 2V4RX53 SVCODE 6236037255
                    post the contents of the bios chip even if it is corrupted..post full name and model, motherboard model,etc.
                      Help with bios OptiPlex 7080 XE Micro
                      no images
                      Service Tag: 3VKK9R3
                      MB: IPCML-RN/ZB rev;A00
                        no images
                        OptiPlex 7080 XE Micro Form Factor
                        Become a Badcaps supporter
                        Thanks to all supporters.
                          Thank you, it worked
                            This chip is shure supported by the RT-809 Programmers. I programmed it with this many times.
                            It seems to be not 100% supported bei the cheap 341-Programmers even with the 3.3V setup. with those programmers i had only problems with this chip.
                            And please check the pinout ! some "standard" 16 to 8 pin adapters delivered with the programmers just not work.
                            i found a post on winraid/levelone which was very helpful.
                            here the mapping 16 to 8 that finally worked for me and those macronix chips.
                              hello bro, my BIOS do not saving Service Tag, can you help me fix it??
                              Service Tag : 6YJGM83
                                Service Tag: 6YJGM83
                                  thank you
                                    my BIOS not saving service tag kindly help me this
                                    DG6Z7B3
                                      DG6Z7B3
                                      OptiPlex 7080 Micro
                                      Service Tag: DG6Z7B3
