BIOS for Dell optiplex 7080 micro
  • IDG
    • Dec 2024
    Ok. So I did a diff on previous submitted and unlocked files and found the edits that were made. Edited my own file, re-flashed and it works :-) Thanks for the info.
    • 90skidjohnny
      • Jan 2025
      • 4
      Hi All.
      So i got a free Little Dell Micro That I want to put linux on to further learn on, however, its Bios Locked with the 8FC8, and I need to change some settings on it.
      Ive been reading this forum, and it looks like this bios can be patched, but in order to do so, i would need a dump of my existing bios, which i dont have. I dont have the equipment to do so either at this time. I wasnt sure if someone had a Bios I could use for this? Im a little confused on how this
      actually works. But im learning!
      Dell micro Optiplex 7080
      Service Tag: 5H9N8B3
      8FC8 Bios lock.
      Need either original bios or patched? Thank you!
      • 90skidjohnny
        • Jan 2025
        • 4
        Just an update.
        Im a moron, I was thinking the Bios could be flashed with software if someone uploaded. but looks like it would need to have a programmer to flash it, which i dont currently have.
        Nevermind then! Thanks anyways
          SMDFlea commented
          Editing a comment
          Thread merged with 7080 micro topic.
      • LEO037_2029_
        BIOS_LEGEND
        • Nov 2023
        • 83
        • Argentina
        90skidjohnny hi i undesrtand your situation, but try with this password = gggggngn and feedback me.
        write this password gggggngn and tell me if work for you -.
        • 90skidjohnny
          • Jan 2025
          • 4
          Thanks for the reply! I did try that one as well , but unfortunately didn't work.
          • Jerem15_
            • Jan 2025
            • France
            #26
            Hey everyone,
            I see a lot of people here sharing their BIOS backups to get unlocked, and I'd like to do the same with my Dell Optiplex 7080 Micro. Can anyone explain how to back up the BIOS properly?
            Thanks a lot for the help
            • Jerem15_
              • Jan 2025
              • France
              #27
              Finally, I did some research, and it seems I need a programmer to back up my BIOS. The BIOS chip is MX25L25673GHI with 16 pins. I'm not sure which exact programmer and clip I should buy. Can anyone recommend a reliable setup that works well for this chip? And, is it possible to back up the bios just by using Windows OS on the computer directly, because i see various app such as Universal BIOS Backup Toolkit that looks fine. Thanks for your help
              • peste
                • Dec 2016
                • 13581
                • ROMANIA
                #28
                see what programmer your bios chip supports..
                • JIM Earthworm
                  • Feb 2025
                  • Rassin
                  #29
                  Tell me where I can get the bios when the firmware is damaged, there is no dumpa, I need a new one. sertag 2V4RX53 SVCODE 6236037255
                  • peste
                    • Dec 2016
                    • 13581
                    • ROMANIA
                    #30
                    post the contents of the bios chip even if it is corrupted..post full name and model, motherboard model,etc.
                    • Shuri
                      • Feb 2020
                      • 8
                      • Latvia
                      #31
                      Help with bios OptiPlex 7080 XE Micro
                      no images
                      Service Tag: 3VKK9R3
                      MB: IPCML-RN/ZB rev;A00
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12330
                        #32
                        no images
                        OptiPlex 7080 XE Micro Form Factor
                        Service Tag: 3VKK9R3​
                        • Shuri
                          • Feb 2020
                          • 8
                          • Latvia
                          #33
                          Thank you, it worked
                          • MMH3
                            • May 2024
                            • 14
                            This chip is shure supported by the RT-809 Programmers. I programmed it with this many times.
                            It seems to be not 100% supported bei the cheap 341-Programmers even with the 3.3V setup. with those programmers i had only problems with this chip.
                            And please check the pinout ! some "standard" 16 to 8 pin adapters delivered with the programmers just not work.
                            i found a post on winraid/levelone which was very helpful.
                            here the mapping 16 to 8 that finally worked for me and those macronix chips.
                            • shiponnice
                              • Dec 2024
                              • 9
                              • Cambodia
                              #35
                              hello bro, my BIOS do not saving Service Tag, can you help me fix it??
                              Service Tag : 6YJGM83
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 12330
                                #36
                                Service Tag: 6YJGM83​
                                • shiponnice
                                  • Dec 2024
                                  • 9
                                  • Cambodia
                                  #37
                                  thank you
                                  • ldinesh51
                                    • Mar 2020
                                    • 4
                                    • India
                                    #38
                                    my BIOS not saving service tag kindly help me this
                                    DG6Z7B3
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 12330
                                      #39
                                      DG6Z7B3
                                      OptiPlex 7080 Micro
                                      Service Tag: DG6Z7B3​
                                      • digitalpc
                                        • Jun 2016
                                        • 305
                                        • .DLL
                                        #40
                                        Hello, I hope you're all doing well.
                                        I'm looking for help from someone regarding the BIOS of a Dell OptiPlex 7080 Micro. Someone tried to remove the password, and after that, the PC no longer gives any display — it just goes into a restart loop.
                                        F8LP8B3 - 8FC8
                                        • mrrubik
                                          Dell Optiplex 7010 micro bad BIOS flash?
                                          by mrrubik
                                          Hi folks,
                                          I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
                                          After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
                                          Steps I took:
                                          1. Read BIOS with CH341a, verified hash twice
                                          2. Patched
                                          12-23-2024, 04:11 PM
                                          DELL OptiPlex 7080 OptiPlex 7000 i5-10500T Specification for Upgrade or Repair
                                          This specification for the DELL OptiPlex 7080 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 7080 boardview and OptiPlex 7080 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          09-12-2024, 03:44 PM
                                          DELL OptiPlex 7080 OptiPlex 7000 i5-10500 Specification for Upgrade or Repair
                                          DELL OptiPlex 7080 OptiPlex 7000 i7-10700 Specification for Upgrade or Repair
