Dell 3040M micro bios ME clear
  • brajomobil
    • Apr 2023
    • 7
    • Hrvatska
    I have dell 3040M (micro). No picture , no amber lights, only constant white light. When remove RAM, beeps and flash 2 amber light. To me it seems bios problem.
    I have attached ori bios. Can someone clear ME , hope it will work ok.
    I have tried to flash bios from working one but it seems not responding, and
    no beeps when remove RAM.
    Programmer is CH340 and I have successfully flashed and repaired 3050 with bios from this forum.
    Thank you in advance.
    Best regards,
    brajomobil
  • brajomobil
    • Apr 2023
    • 7
    • Hrvatska
    Re: Dell 3040M micro bios ME clear
    Managed to clear ME by this tutorial: https://www.badcaps.net/forum/showthread.php?t=88533
    But I have the same problem , no picture.
    Tried with working bios from another machine and clear ME, no luck.
    I guess something other it wrong.
    Best regards,
    brajomobil
    • brajomobil
      • Apr 2023
      • 7
      • Hrvatska
      Here is bios 3040M with clear ME.
      Best regards,
      brajomobil
      • brajomobil
        • Apr 2023
        • 7
        • Hrvatska
        Fixed. Working OK. After flashing bin file power on and leave it for 15-25min.
        After that boot windows and flash bios 1.20. PC works ok.
        I was ready to gave up , but
        Best regards,
        brajomobil
        • wilyfog
          • Sep 2011
          • 4
          Best regards,
          brajomobil
          Hi, I'm facing a similar problem with my Dell 3040M micro.
          I think my bios is also currupted.
          So if I understand your last post:
          1.- flash the rom with outimage1.bin
          2.- power on the dell and leave it for 15-25min
          3.- Power off / on and it's supposed to boot into windows
          4.- Update bios to 1.20
          Did you insert your Service Tag nº in the outimage1.bin file?
          During step 2, what color has the power on led?
          Will it work if I use the same outimage1.bin file in my 3040M micro?
          Thanks and best regards.
          • brajomobil
            • Apr 2023
            • 7
            • Hrvatska
            Your steps 1-4 are correct.
            Inside bin file is my serial number. you can change it by hex editor.
            it is found on 2 places in bin file.
            Led is constant amber than after 15 min white.
            Yes you can use my bin it is ME cleared.
            • wilyfog
              • Sep 2011
              • 4
              Thanks for your fast reply.
              Don't you mind and tell me your serial nº (service tag) so it will be easier for me to search and replace with mine?
              I'll let you know of the results.
              Thanks a lot.
              • brajomobil
                • Apr 2023
                • 7
                • Hrvatska
                my unit is sold.
                pull your bios to bin than find yours serial number in hex.
                remember position then you can find it in my bin.
                it is in 2 positions. change serial on both position
                best regard,
                brajomobil
                • mrrubik
                  Dell Optiplex 7010 micro bad BIOS flash?
                  by mrrubik
                  Hi folks,
                  I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
                  After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
                  Steps I took:
                  1. Read BIOS with CH341a, verified hash twice
                  2. Patched
                  12-23-2024, 04:11 PM
                • zenius
                  by zenius
                  12-08-2024, 06:13 AM
                • mikeybass
                  by mikeybass
                  04-23-2025, 04:30 PM
                • capoplays
                  Help with BIOS update on Dell G15 5515 after chip replacement
                  by capoplays
                  Hey everyone,
                  I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                  The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                  When I check the BIOS using the F12 menu Flash...
                  10-24-2025, 06:53 AM
                • tracks
                  Dell 3080 Micro BIOS dead
                  by tracks
                  Hello all,
                  I have a Dell 3080 Micro with a problem. As it is right now, it seems to be boot looping, maybe... There's no output, just fan on and power led lights up and blinks off every 2 seconds or so.
                  Previous owner told me he bought it with a BIOS password, he tried to use a CH341A programmer with some random test clip and tried to mess with it while it was powered on. Now it won't boot.
                  I tried to dump the bios with an EZP2023+ but I can't get a consistent read. Every time the dump is different, so it's unusable. I think the BIOS chip is fried.
                  04-19-2025, 03:42 PM
