Asrock P4i945GC - boardview or component finding
  • N²x²N
    • Apr 2023
    • 54
    • Italy
    Hello, I'm new to this forum.
    On another forum I was directed to come here for better assistance.
    Issue:
    I got this motherboard with a burnt trace and a burnt SOT-23.
    On top it has M091 (I think it's a AP2309GN
    https://www.alldatasheet.com/datashe.../AP2309GN.html).
    This sot-23 connects to the mosfet that then powers the trace that got burnt.
    It had a blob and a broken leg on the S-D path, G was spared but it shorts to both S and D.
    I can't identify, for sure, what this is and my only solution is to either get the .fz file or get lucky and have someone tip me on what it was.
    I was suggested to try a 0.5 or 1A fast blow fuse on the S-D path and see what happens.
    Thanks for any help!
    (My english isn't up to the task but I hope not too bad either.)
  • N²x²N
    • Apr 2023
    • 54
    • Italy
    Re: Asrock P4i945GC - boardview or component finding
    Up!
    • N²x²N
      • Apr 2023
      • 54
      • Italy
      Up!
      • electomech-fixer
        First post -Intel NUC 10i5 -BXNUC10i5FNH not powering on -IC burnt- request for IC details/datasheet
        by electomech-fixer
        I came across this very active forum with knowledgeable folks on electronic circuits and components, while google searching for the details of my burnt IC marked 7603 in Intel NUC board. I joined this forum today and this is my first post here.
        I recently got an Intel NUC 10i5 and had installed Linux Mint and was using it for about a month when it died suddenly and did not power up after that.(Power Adaptor is ok). When I opened the NUC , there was a burnt IC marked 7603 (and ILCB in second line). I am unable to find the details/datasheet of this IC. I will be grateful if...
        09-15-2025, 01:42 AM
      • N²x²N
        Asrock P4i945GC - component id
        by N²x²N
        Issue:
        This sot-23 connects to the mosfet that then powers the trace that got burnt (se pics).
        Source is from +5VSB; Gate is +5V can't figure from where.
        I can't identify, for sure, what this is and my only solution is to either get the .fz file or get lucky and have...
        04-03-2023, 09:31 AM
      • gurj1979
        ASRock B550M-ITX/ac - Need help with SOT23
        by gurj1979
        Hi guys.
        So I've got hold of a board mentioned above.
        Need help finding a suitable replacement Transistor/MOSFET of SOT23-3. 2 are blown.
        SMD Marking is A3OAK but I can't find this anywhere on the internet, not even AliExpress.
        What can I use instead of these.
        Multimeter continuity shows it connects to the LED RGB Header.
        So these are LED Drivers, but are they Transistors, Diodes, or MOSFET's ?
        Anyone please help.
        See pics.
        Thanks...
        02-22-2023, 06:10 AM
      • gabrieljma1
        Request: Full BIOS dump for ASRock Z790-CX (DDR5)
        by gabrieljma1
        I’m looking for a full raw 16 MB BIOS dump for an ASRock Z790-CX (DDR5) motherboard.
        The board powers on (fans spin, RGB lights on, RAM LEDs active), but there is no display output and the VGA and BOOT LEDs stay lit.
        I’m using an Intel i9-14900KF CPU (14th gen), and it seems the BIOS version on my board doesn’t support it yet. I tried to flash the official ASRock BIOS file (renamed .ROM → .BIN) directly using my RT809H programmer, but it didn’t work — monitor stays on but with black screen, so I believe the ASRock update file is not a complete...
        10-08-2025, 03:32 PM
      • Exim
        ASRock N100M, no picture no boot, but semi-alive
        by Exim
        Hi guys,
        I managed to semi-kill an ASRock N100M board after updating Bios from 1.10 to 2.01. It's a zombie now, dead, but not dead.
        ASRock N100M special features:
        - CPU soldered to board, small Intel 12th gen
        - iGPU
        - four POST LEDs
        Problem after updating Bios to 2.01 using the in-Bios update tool: no picture, no boot.
        I am not sure anymore if it booted at least once successfully after updating the bios to 2.01, maybe not, I can't remember. I think it did not.
        Symptoms:
        - no picture/signal on any of the display connectors,...
        04-01-2025, 02:36 PM
