HP Prodesk 400 G6 mini admin bios password
  • vilmar27@hotmail.com
    • May 2023
    • 30
    • Brasil
    Please, anyone have the MPM Unlocked BIN File for HP PRODESK 400 G6 Desktop Mini PC?
    I have two units that after Windows Update corrupted the BIOS, now I try to power on, but the units show 2.2 Beeps Codes and not complete the POST, the Windows Updated applied BIOS update in these units and corrupted. (I tried many times the Bios Recover process with PenDriver, but not worked).
    Serial: BRJ2412YRJ & BRJ2412X4M
    Part: 6Z772LP​
    Best Regards,
    Vilmar
      • May 2023
      • 30
      • Brasil
      Please, I found other unit with BIOS ok, but anyone could help change the MPM to Unklock and clear the BIOS Password for this HP 400 G6 Mini?
      Serial: BRJ228ZZ5J
      Part: 63U61LP
      Best Regards,
      Vilmar
      • hoaca388
        Badcaps
        • Jan 2022
        • 11191
        • Viet Nam
        Serial: BRJ228ZZ5J
        Part: 63U61LP
        Best Regards,
        Vilmar
        What's password ? There is no password in the bios at all.
          • May 2023
          • 30
          • Brasil
          Hi, Hoaca388!
          Ops, for this unit have no password, now I only need to unlock the MPM to replicate this BIOS BIN file to other two units that corrupted the BIOS and no complete the Post, show 2.2 beeps. (I posted it in 5-21-2024, 06:38 AM).
          It is posible replicate this BIN file from one unit to other two units and change the BIOS Serial Number?
          Thanks a million,
          Vilmar
          • hoaca388
            Badcaps
            • Jan 2022
            • 11191
            • Viet Nam
            Hi, Hoaca388!
            Thanks a million,
            Vilmar
            Try
              • May 2023
              • 30
              • Brasil
              #26
              Hi, Hoaca388!
              Thanks a lot.
              This BIN file removed the BIOS information as Serial, SKU, Feature Byte, Build ID, but not turn on the MPM and I cannot edit the informations.
              Manufacturing Programming Mode
              Unlock
              *Lock
              Could you help me?
              And also is posible edit the MAC Address for each unit to avoid have 3 units in same network with same MAC Address that can cause mac conflit.
              I really appreciate if you help to find these two below information in the BIN file that I can edit with information of each machine?
              Integrated MAC Address 1
              30-24-A9-FC-0A-F9
              MS Digital Marker
              010000000000000001000000000000001D000000504E3743562D594B37514A2D504D5744572D56504238382D47564B4354
              Best Regards,
              Vilmar​
                • May 2023
                • 30
                • Brasil
                #27
                Hi, Hoaca388
                Please, could you help me with these units to Unlock the MPM for edit Serial, other BIOS information and edit MAC Address number?
                Tks,
                Vilmar
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 11191
                  • Viet Nam
                  #28
                  Hi, Hoaca388
                  Tks,
                  Vilmar
                  Try
                  • EagleEye812
                    • Apr 2024
                    • Belgium
                    #29
                    Is there anything specific I should do differently to properly read the BIOS off this motherboard?
                    BIOS Chip = GD25B256D
                    - CH341a black board with the correct drivers installed
                    - I'm using Neoprogrammer 2.2.0.10 configured to GD25Q256
                    - Using a SOP16 clip with the following pin mapping: Summary:
                    • BIOS Chip Pin 2 (VCC) -> CH341a Programmer Pin 8 (VCC)
                    • BIOS Chip Pin 10 (VSS) -> CH341a Programmer Pin 4 (VSS)
                    • BIOS Chip Pin 7 (CS#) -> CH341a Programmer Pin 1 (CS)
                    • BIOS Chip Pin 8 (SO / IO1) -> CH341a Programmer Pin 2 (MISO)
                    • BIOS Chip Pin 15 (SI / IO0) -> CH341a Programmer Pin 5 (MOSI)
                    • BIOS Chip Pin 16 (SCLK) -> CH341a Programmer Pin 6 (SCK)
                    • BIOS Chip Pin 9 (IO2) -> CH341a Programmer Pin 3 (WP)
                    • BIOS Chip Pin 1 (IO3) -> CH341a Programmer Pin 7 (HOLD)
                    - PSU disconnected from the main board, and I've tried with both CMOS battery IN and OUT.
                    However, Neoprogrammer is telling me "IC not responding" which indicates to me that I'm doing something wrong... The machine itself blinks a couple of error codes with its status led as soon as the CH341a is connected.
                    Any hints?
                      • May 2023
                      • 30
                      • Brasil
                      #30
                      Originally posted by hoaca388
                      Try
                      Thanks a million Hoaca388. I will test it tomorrow.
                      • guete
                        • Jun 2024
                        • spain
                        #31
                        Good night. Can anyone help me remove the password from an HP 400 G6 Mini?
                        serial: 8CC1010H8N
                        Then I need to activate kvm in amt. Do you have a link with the steps to follow?
                          • May 2023
                          • 30
                          • Brasil
                          #32
                          Hi, Hoaca388!
                          Now worked fine and the MPM is unlocked.
                          Thanks a million for help. You is the BEST!
                          Please, could you help me with more these information?
                          I need to replicate this BIN file to other two below units that are with corrupted bios and not complete the POST, but I want to save the original MAC Address and MS Digital Marker befoure apply this BIN file in these units. (It is to avoid network conflit if replicate same MAC Address in more units in same enviorement....).
                          Serial with corrupted BIOS: BRJ2412YRJ & BRJ2412X4M
                          Part: 6Z772LP
                          It posible read these two information from bad bios units and replicate this information in this BIN file that you changed? Similar of below information.
                          30-24-A9-FC-0A-F9
                          MS Digital Marker
                          Thanks a million,
                          Vilmar​
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 11191
                            • Viet Nam
                            #33
                            Hi, Hoaca388!
                            Part: 6Z772LP
                            30-24-A9-FC-0A-F9
                            MS Digital Marker
                            Thanks a million,
                            Vilmar​
                            Look th picture
                            • unick
                              • Mar 2019
                              • 21
                              • Romania
                              #34
                              i have HP 400G6 mini with GigaDevice 25B256DFIG with password. I desolder the chip , read , save (32 not 16) and i have used HP unlocker (not RC) but no succes to remove password. I write back the original file and now no signal on screen.
                              What i made wrong? Can someone explain the steps?
                              I have atached the bin file
                              Serian Number 8CC112193R
                                • May 2023
                                • 30
                                • Brasil
                                #35
                                Look th picture
                                You is the BEST.
                                Thanks a mllion and have a great day!
                                  • May 2023
                                  • 30
                                  • Brasil
                                  #36
                                  Look th picture
                                  Hi, Hoaca388!
                                  Sorry but could you help with one more information?
                                  I want find this below information in the BIN file do save from bad BIN and apply in the new BIN file to avoid issues to active Windows after I replicate the BIN file to other two units.
                                  MS Digital Marker
                                  010000000000000001000000000000001D000000504E3743562D594B37514A2D504D5744572D56504238382D47564B4354​
                                  I tried to found in the BIN file, but I not located this information....
                                  Best Regards,
                                  Vilmar
                                  • J. Kirsch
                                    • Jun 2024
                                    • België
                                    #37
                                    Any hints?
                                    Hi did you manage to read the chip?
                                    Having the same problem, if yes would you mind to share?
                                    • beBoss
                                      • Mar 2023
                                      • 19
                                      Re: HP ProDesk 400 G6 Desktop Mini PC BIOS Password Help
                                      RCUnlocker is designed to deal with 16MB files not 32MB files. If you want to do it by yourself, you have to compare between locked and unlocked files till you learn. Otherwise you can upload the file in a proper thread, and someone will try to help you.
                                      What is this supposed to mean? Where we can read how to do it by ourself, any information?
                                      I have the same PC and I am trying to remove the password but the RCUnlocker says wrong chip and to find 16mb, but this is the right one, same as the user above.
                                      I bought the 1.7 version of the CH341 Green Programmer.
                                      After 2-3 hours of manually connecting the cables and checking against the chip scheme, I finally managed to read the BIOS—or at least I think I did.
                                      It seems like the connection with the clip is a bit unreliable, which was probably causing most of the issues. Some pins might not have been working properly either.
                                      One more question. How to find the password and decrypt it, is there info somewhere what they use? Any tips and hints?
                                      Thank you!
                                      Serial No: 8CC1270DH6
                                      Product No: 47L40EA#ABZ
                                      Also I don't have in the list of IC the same chip: GD25B256DFIG
                                      I am reading it as:
                                      GD25LQ256C-1.8v with AsProgrammer 3.15 -> 32.0 MB
                                      GD25LQ256C-1.8v with AsProgrammer 2.0.4-> 32.0 MB
                                      GD25Q256 with NeoProgrammer 2.2.0.10 -> 32.0 MB
                                      GD25B512ME with NeoProgrammer 2.2.0.10-> 64.0 MB
                                      Reading with and settings:
                                      Ch341A Programmer V1.7 1.8V Level Shift with the default settings for 3.3V
                                      Thanks for the help.
                                      • beBoss
                                        • Mar 2023
                                        • 19
                                        GD25Q256-NeoProgrammer-2.2.0.10.zip
                                        • raffa555
                                          • Nov 2024
                                          • 4
                                          • italy
                                          #40
                                          Please, anyone can help me with a 400 G6 Desktop Mini PC? The BIOS got corrupted during updates (5long+2short beeps, EC firmware is invalid)
                                          i'm a newbe in such things.. I read the chip and saved the BIN with CH341A (NeoProgrammer 2.1) and it seems to be corrupted.
                                          Does anyone can fix it?
                                          Serial: 8CC1345315
                                          Part: 1C7A3EA#UUZ
                                          Thanks for the help!
                                          • beBoss
                                            HP ProDesk 400 G6 mini - BIOS Password attempt to remove it
                                            by beBoss
                                            as noobie to this please excuse my lack of experience.
                                            I am trying to remove a BIOS password from this machine:
                                            HP ProDesk 400 G6 Mini
                                            but so far I still have no success.
                                            I bought CH341 programmer and decided to give it a try.
                                            The programmer came with 8 pin cables and connectors or whatever everything else is called so I had to buy a new 16 pin cable because the chip which I think is the BIOS is with 16 pins..
                                            I connected everything and downloaded AsProgrammer and NeoProgrammer then installed drivers...
                                            05-30-2024, 12:48 PM
                                            HP ProDesk ProDesk 400 G2 Desktop Mini PC (ENERGY STAR) ProDesk 400 i5-6500T Specification for Upgrade or Repair
                                            This specification for the HP ProDesk ProDesk 400 G2 Desktop Mini PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk ProDesk 400 G2 Desktop Mini PC (ENERGY STAR) boardview and ProDesk ProDesk 400 G2 Desktop Mini PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                            09-12-2024, 03:44 PM
                                            HP ProDesk Desktop Mini ProDesk 600 G2 ProDesk 600 i7-6700T Specification for Upgrade or Repair
                                            This specification for the HP ProDesk Desktop Mini ProDesk 600 G2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk Desktop Mini ProDesk 600 G2 boardview and ProDesk Desktop Mini ProDesk 600 G2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            HP ProDesk ProDesk 600 G2 Desktop Mini PC ProDesk 600 i5-6500T Specification for Upgrade or Repair
                                            This specification for the HP ProDesk ProDesk 600 G2 Desktop Mini PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk ProDesk 600 G2 Desktop Mini PC boardview and ProDesk ProDesk 600 G2 Desktop Mini PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
