HP ERICA5 87D7 Mainboard BIOS bricked
  • REpairAT
    • Nov 2020
    • 142
    • Austria
    got a system, crashed meanwhile BIOS Update.
    Attached, the broken BIN and the EXE from HP Site, which should contain the new BIOS, but I'm unable to extract it for some reason.
    Would be could if someone can fix that for me. Thanks a lot!
    • 20965
    Re: HP ERICA5 87D7 Mainboard BIOS bricked
    What model is it ?
    https://www.bestbuy.com/site/questio...9-cf82ee65279f
    The motherboard on the M01-F1114 desktop is Erica 5 SSID 87D7. See the motherboard specification here: https://support.hp.com/ie-en/document/c06945872.
    • REpairAT
      • Nov 2020
      • 142
      • Austria
      Originally posted by SMDFlea
      What model is it ?
      The Model is named HP Pavilion Gaming Desktop PC TG01-1912ng
      Serial 4CE1022ZHR
      Product ID 2H5G7EA#ABD
      Mainboard ID19 ERICA3_ERICA5 REV:A
      • hoaca388
        Badcaps
        • Jan 2022
        • 11772
        Serial 4CE1022ZHR
        HP Pavilion Gaming Desktop PC TG01-1000a (2W847AV)
        • REpairAT
          • Nov 2020
          • 142
          • Austria
          Same as before. Without SSD, it does not even POST.
          With SSD connected, it shows the following in a loop:
          • eric2022
            Ericscott
            • Jan 2022
            • 46
            • Uganda
            HP ID19 Erica3_Erica5 Rev: A
            model M01 F1078ur
            4CE201CM5J
            • vladrak
              • Aug 2020
              • 5
              • Russia
              Hello. Found a solution to the problem? I have exactly the same problem. Without SSD there is no post. BIOS update error with SSD.
              • Foryou Tosee
                • Jan 2025
                Same problem 5 years ago. Any solve?
                • gs84
                  • Dec 2022
                  • 36
                  • Ukraine
                  just need to plug USB key with BIOS updating files
                  • studdy05
                    Bricked HP Probook 450 G7 Bios questions
                    by studdy05
                    Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                    Ive got...
                    07-08-2025, 09:24 PM
                  • macabook
                    by macabook
                    🧩 Initial Issue
                    07-24-2025, 02:17 PM
                  • DavidChunco
                    Dell G15 5515 Ryzen Edition Apparently Bricked BIOS Request
                    by DavidChunco
                    Hi, I hope someone can help me with this, my Dell G15 Ryzen Edition does not post anymore (black screen, no Windows boot, no BIOS screen) after Windows Update pushed what appears to be a buggy bios image, I've tried the following with no success:
                    - Receive help from Dell Support (it is out of warranty).
                    - Disconnect machine from AC power and battery overnight.
                    - BIOS recovery process
                    - Connected external display via HDMI
                    - Disassembled machine and found bios chip, its a Gigadevice 25LR128DSIG (GD25LR128DSIG), at first I tried to get it detected by CH341A (with...
                    03-15-2025, 11:00 AM
                  • Vesko356
                    by Vesko356
                    08-11-2023, 03:27 AM
                  • Fr33man
                    BIOS file (.BIN) for semi-Bricked IdeaPad 3-14ALC6
                    by Fr33man
                    I soft BRICKED my Lenovo IdeaPad laptop (black screen with led lights on, responsive keyboard backlight, fans spinning) after messing about with a Github tool called Smokeless. I am now attempting to reflash the bios through USB, but I am not sure if I extracted the correct BIOS ROM file to flash, and I also could not find the correct file name to rename it to (GLCrisis.bin, GLCN.bin, Currom.bin??). In addition to attempting to reflash the Bios with a USB, I have also performed the following activities:
                    *Novo button power on
                    *Disconnected internal battery...
                    09-23-2024, 01:16 PM
