Password bios Dell Optiplex 5090
  • peste
    • 13550
    • ROMANIA
    #41
    Originally posted by Nikosz
    Hello. Does anyone have a BIOS file from OptiPlex 5090 Tower?
    thanks
    post S/T, full name and model, motherboard model, etc.
    post the contents of the bios chip even if it is corrupted..
    • AAJO
      • Apr 2025
      • TUNISIE
      #42
      Hi Badcaps Giants,
      I need help please.
      Service Tag : 6G7C8K3-8FC8
      • danito
        • Jun 2016
        • 1091
        #43
        Originally posted by AAJO
        Hi Badcaps Giants,
        I need help please.
        • Hamazzz
          • May 2025
          #44
          I Have 2 5090 optiplex's that have the Bios admin locked, both on 8FC8 Bios, i have a ch341a but only with a 8 pin clip, have ordered a 16pin clip, the chip on the motherboard is a Winbond 25R256JVFN, would i need to modify the 16pin clip one i get it, or will it work with no modification? i have the v1.7 of the ch341 with voltage adjustment.
          • Hamazzz
            • May 2025
            #45
            Badcaps Giants,
            Service tag 8R1FNM3-8FC8 Optiplex 5090 SFF
            Need some help,
            Managed to read the 25R256JVFN bios chip, took 2 copies, made the modification of searching for "00 FC AA" and replacing it with "00 FC 00" ( nothing came up on this one ), then the same for "00 FD AA" and replacing it with "00 FD 00"​ had 2 entries. Erased the chip and wrote the modified bios file to the IC, pc would not boot at all, only orange power light came on and off.
            Erased the bios again and wrote the original copy, still would not boot, any ideas?
            Both files attached
            Any help appreciated, Thanks
            • hoaca388
              Badcaps
              • Jan 2022
              • 12316
              #46
              Badcaps Giants,
              Need some help,
              Both files attached
              You failed because the backup failed.
              • Hamazzz
                • May 2025
                #47
                How can i verify the backup is correct before erasing the Bios chip?
                I have another identical unit, will pull the backup off that and try and put it on the 1st machine before proceeding.
                Hamazz
                • Ramin Oqabi
                  • Jun 2025
                  • Afghanistan
                  #48
                  hi plz unlock admin password bios dell 5090 optiplex micro
                • lapfix
                  • Mar 2020
                  • 2764
                  • my workshop
                  #49
                  1st boot, press F2, write service tag, disable Absolute, save, restart.
                  2nd boot press Alt+F to exit manufacturing mode.
                  Good luck.​
                  • drwany60
                    • Mar 2018
                    • cairo
                    #50
                    PEZ SIR HELP ME TO REMOVE PASSWORD SETUP
                    DELL OPTIPLEX TOWER 5090
                    SERVICE TAG (DS14QP3)
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 12316
                      #51
                      3.4. Dell
                      Dell laptops store the password in EC. However, some generators exist depending on the code suffix.
                      See: https://beta.bios-pw.org/ .If the website is offline try: https://web.archive.org/web/*/https://bios-pw.org/
                      Note: All passwords must be entered with a US QWERTY Keyboard,you can use a USB one.
                      Note: The 6FF1 suffix has a bug,use your service tag with the 1F5A or BF97 suffix instead,Example: 1234ABC-BF97 .
                      Note: The list of examples does not include some other suffix codes that do work,such as E7A8 .
                      Note: If the BF97 suffix does not work try it with the E7A8 suffix instead.
                      Note: There is no publicly available 8FC8 generator available at the moment.
                      The CTRL-ENTER-ENTER keystroke after the password only applied to laptops with a suffix (xxxxxxx-8FC8 for example), until Dell also required it in some laptops using System Disable 16-Hex algorithm, on which only the Password+ENTER was needed at first and then in some models you needed the CTRL-ENTER-ENTER to properly delete the system passwords, otherwise the password would remain SET upon the automatic system reboot if just doing Password+ENTER until the proper CTRL-ENTER-ENTER keystroke was performed in certain models.
                      8FC8 Patcher software: https://www.badcaps.net/forum/troubl...l-8fc8-patcher
                      • zenius
                        by zenius
                        12-08-2024, 06:13 AM
                      • overclocker1786
                        [Bios Password Unlock Request] [Dell OPTIPLEX SFF PLUS 7020] [8FC8 method]
                        by overclocker1786
                        Hello I have a dell optiplex SFF plus 7020 with a password that I recovered from e-waste. It is possible to get the password removed via the bios patch method? I managed to dump the 32MB bios chips and would like help patching it to MFG mode so I can clear the password.
                        Thanks.
                        1hj4z24 = Service tag
                        A schematic would also be amazing if anyone has one!...
                        08-31-2024, 08:46 PM
                      • CuteWildCat
                        BIOS Admin Password remove for Dell Optiplex 3090 SFF
                        by CuteWildCat
                        Hello there,
                        My Dell Optiplex 3090 bios is locked with admin password. Worst of all, it seems.
                        Here is my system number 1THQMS3-8FC8.
                        I don't have the hardware to dump my bios, and I can't pay 400€ to hope to get a password from a guy I don't even know exists. So without conviction I'm wondering if anyone here can help me.
                        Thank you in advance...
                        01-01-2025, 02:23 PM
                      • lamtran20
                        Dell Optiplex 7480 AIO Bios Password Removal Help
                        by lamtran20
                        Serial Number: BBTSQ53
                        Dell Optiplex 7480 AIO. It is bios locked, any help removing the password would be greatly appreciated....
                        11-15-2024, 04:52 PM
                      • mikeybass
                        by mikeybass
                        04-23-2025, 04:30 PM
