DELL XPS 8930 motherboard bios needed
  • seanxxx316
    • Feb 2022
    • 7
    Was updating the bios on a DELL XPS when the power shut off abruptly was looking for a bios bin file so I can directly flash the bios chip to get the pc back up and running. I have already tried updating using recovery can not get it to do anything other than power on. If needed the spec of the system are IPCFL-VM motherboard i7 8700 GTX 1070 1tb SATA HDD 8gb ram 500w PSU
  • hardware1
    • Sep 2021
    • 2946
    • N/A
    Re: DELL XPS 8930 motherboard bios needed
    We will need your Backup Bios even if it's corrupted, your Bios could be in one Chip or divided into 2 Chips.
    Also write your Device Service Tag.
    all donations are welcome,
    • seanxxx316
      • Feb 2022
      • 7
      Service tag info sticker on this one has been removed so no idea there the bios file is below
      • hardware1
        • Sep 2021
        • 2946
        • N/A
        Here's your New Bios, try it and let me know.
        Service Tag: 39RNMR2.
        • seanxxx316
          • Feb 2022
          • 7
          That did it up and running again. Thank you very much.
          • hardware1
            • Sep 2021
            • 2946
            • N/A
            Glad to know, You're Welcome.
            • teccyber-lab
              • Apr 2025
              • 26
              • BRAZIL
              Hi Folks , I need to repair this BIOS. A little background history, was freezing the image, the keyboard was not responding so I could not restart the graphics driver, and the mouse pointer disappeared, it is random after 2 hours or 1 hour, it worked to turn it off directly by pressing the power button for more than 10 seconds it would turn off, if I decided to turn it on again in less than a minute it would freeze again.
              I did different tests (memtest86, furmark, aida64) and nothing conclusive came up. In fact, it says that everything is fine. On the third day of testing, it stopped generating video. I am now testing the video rtx2070 on my computer and it is ok, so I suspect that the BIOS is somewhat corrupted. It is worth noting that it was updated to the latest version at the beginning of the tests.
              Model XPS 8930
              MoBo: IPCFL-VM Rev. A00
              ST: 90X9423
              Any indication I would be very grateful
              • glovecaps
                Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
                by glovecaps
                I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
                My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
                The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
                11-25-2024, 04:23 PM
              • zaraky77
                Dell M15 R4 bios motherboard GDR51 LA-K741P
                by zaraky77
                I've a laptop Alienware M15 R4 motherboard GDR51 LA-K741P with rtx3080
                sn: BD6N9C3
                I've setup a long time ago an Admin and a system password. I can run / install OS with the system password but unfortunately i've forgot the admin password so now i can't update my bios. (it asked the admin psw for instal)
                I've contact the Dell support for the Admin password in bios and the asked me the system id /challenge password but it won't show up the windows in bios just says you've fail 3 times system restart.
                They gave me a code 38DCEE5F to reset...
                09-04-2025, 10:11 AM
              • re1nhold
                Bios needed, Dell E5550, Tag FSFB262, Zam80 La-911P Rev.1
                by re1nhold
                Hello Guys
                I'm currently fixing two different Dell latitudes,
                I need a E5550 BIOS - SERVICE TAG is: FSFB262
                So far I flashed about 6 BIOS from this forum already,
                none worked,
                only fan spin ~3s, LCD black, keyboard LED on/off ok,
                I tried manual extraction with scripts for ages so to speak. VM is untried yet.
                This laptop is not burnt, it seems to just have a corrupted BIOS.
                I extra baught ram. This has to work friends.
                Do you generate it this way in Windows in CMD?:
                Code:
                E5550A24.exe /writeromfile C:\bios.fd
                07-18-2025, 09:18 AM
              • mrrubik
                Dell Optiplex 7010 micro bad BIOS flash?
                by mrrubik
                Hi folks,
                I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
                After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
                Steps I took:
                1. Read BIOS with CH341a, verified hash twice
                2. Patched
                12-23-2024, 04:11 PM
              • bmxlovah
                Dell Precision T7910 no bios, no post after applying SAS/RAID setup
                by bmxlovah
                My Dell Precision T7910 died after enabling onboard SAS controller and applying RAID settings. There were no hardware changes between working and not working state, only setup (via bios -> controller settings). After applying settings and reboot PC turns on, flash leds (normally) but there's no further action, it just stays on with no graphics and no keyboard led's on. There's no Dell logo, nothing. I've tried resetting bios by jumper, replacing cpu's, replacing ram, removed/replaced cmos battery, disconnecting all drives etc. I've also dumped .bins from mobo chips SLI1 (16...
                11-24-2022, 06:29 AM
