eVGA 7600GT Cap Replacement Question
  • buriedpast
    Still Learning
    • Aug 2010
    • 5
    Hi all, this is my first post here and first thought on recapping. Old hat with soldering, so I figure this will be a nice project.
    My 7600GT has the infamous Sacon FZ caps that I'm going to replace - it died yesterday and I couldn't figure out what happened until finding this site and remembering the couple of "pops" I heard ... rung a bell.
    I''ll replace all 3 types: 470 uF 16V, 1000 uF 16V and 1500 uF 6.3V. From what I've determined on the forums, the FZ ripple/ESR specs are 1,800 and 0.022.
    The replacement Rubycon I figure to buy here will be: MCZ for the 1500 and 1000 caps and MBZ for the 470 caps.
    I've read many recommendations for the MCZ and MBZ caps as replacements for Sacons and also have read that I should replace with "more ripple and less ESR". The MCZ caps meet that spec, but it appears the 470 MBZ will be exactly opposite with a ripple = 1140 and ESR = 36 (which I assume is actually 0.036)
    Will using the 470 MBZ present a problem? And if so, any recommended cap for a replacement?
    Thanks in advance.
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: eVGA 7600GT Cap Replacement Question
    That help a little?
    Mann-Made Global Warming.
    - Dr Seuss
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      ESR is like resistance to ripple.
      - Less is better.
      [Because the caps job is to short the Ripple to ground.]
      The Ripple Current rating is how much Ripple it can pass without overheating the cap.
      - More is better.
      [If a cap were a resister that characteristic would be called Watts.]
      - Dr Seuss
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        Yes.
        You didn't give diameters so I dunno which FZ [specs for] you are replacing.
        - Dr Seuss
        • buriedpast
          Still Learning
          • Aug 2010
          • 5
          PCBONEZ -
          That helps a lot!!! ... I was assuming that all FZs were the same ripple and ESR specs based upon what I read earlier. Obviously, I was wrong and with the information you provided, the 470s meet the old FZ specs.
          And as for the diameters, all but the 470s are 10 mm, the 470s are 8mm. It looks like I'm good to go with the Rubycoms ... and for my first recapping.
          Thanks a lot for the quick response!
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            No worries.
            Sacon's site went *poof* some time in 2008 so the data sheet isn't easy to find on the web anymore.
            - Dr Seuss
            • buriedpast
              Still Learning
              • Aug 2010
              • 5
              Well, I got my caps and replaced all of them and boy, did it look sweet when I was through. But, (don't you love the 'but'?) when I powered up the computer with the board installed, no video and then smoke!! That little component at the top right of the board labeled "1R5" has a little coil in it that started glowing red hot!
              I don't know what's up ... this didn't happen when the board was installed with the blown FZ caps and the fan still powered up at that time. I guess it's time to toss it unless anyone has some suggestions.
              Still, it was a learning experience. A disappointment though, especially when reading about Topcats experience buying a bunch off of ebay and having all but 2 work when the caps were replaced.
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                Bummer.
                1R5 means 1.5 and that's the inductor in the filter circuit it and those two nearby caps make up.
                Bad caps can stress or nreak other parts.
                The bad FZ probably toasted those MOSFETs near it or shorted whatever the load on it is which is presumably the GPU itself.
                - Dr Seuss
                • Toasty
                  • Jul 2007
                  • 4171
                  Solder bridge? Check those 2 caps for shorting. Check the MOSFETs too.
                  veritas odium parit
                  • buriedpast
                    Still Learning
                    • Aug 2010
                    • 5
                    I doubt there's a solder bridge. Although I'm not experienced with this type of effort, I've modded many game systems starting with the PS1 - I'm no newbie to soldering. But things DO happen, so I'll check for that. The question is how to do it? I'll remove the caps, look at the board and measure resistance to make sure the caps aren't shorted. Is that all?
                    As for the mosfets, do I need to remove them to test? If not, any guidance on what to do to check them out? I seem to recall reading here somewhere that I need to lift a leg and then check for something.
                    Thanks again. This is just a learning experience / project now. Already bought a new video card, but it would be nice to bring this one back from the dead.
                    • Toasty
                      • Jul 2007
                      • 4171
                      Had a nice reply until the damn board wiped it.
                      Meter the caps. No desolder.
                      Meter FETs, no desolder. All same reading is suspect. Find thread in here on MOSFET testing.
                      veritas odium parit
                      • chth96
                        Is it no harm to replace with capacitor without ripple current rating?
                        by chth96
                        When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                        Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                        But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                        Rubycon YK DataSheet (b...
                        04-19-2024, 05:19 AM
                      • Bugmanscj
                        Audio Linear Power Supply (LPS)
                        by Bugmanscj
                        Hi: Found this forum fumbling over the net looking for replacement capacitors for a high quality 2uv ripple model Kaia, Core Audio Technology LPS. I bought it used on fleabay and figured I would have to recap and sure enough one of the 22,000uf 35V 105c caps is bulging. These supplies were made briefly around 2014 for MAC Mini audio servers, and were quite costly at the time ($1.7k), you know it's audio... I will use it for a video processor power supply to replace a switched version. I figure it's a low cost attempt to see/hear what difference it might make in my system. Plus I get to learn...
                        02-17-2025, 08:50 AM
                      • the_rem
                        Unknown transformer : how to find a good replacement part ?
                        by the_rem
                        Hello guys,
                        I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
                        I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
                        04-23-2025, 01:48 AM
                      • JohnsonJ
                        Allen&Heath XONE92 DJ mixer repair
                        by JohnsonJ
                        Hello everyone.
                        I'm having issues with my DJ mixer, and after taking it apart and checking everything out, it seems that I need to replace 2 rotary potentiometers for the filter, and that the PSU has some caps burned. Hopefully these 2 fixes will solve my issues.
                        The potentiometers I will just replace (hopefully the repairman I spoke with will indeed send me the spares, in case he doesn't, I'll update here if we can find a suitable replacement), but for the PSU caps I'd kindly ask you forum members, if anyone could help guide me in the right direction. I'm having difficulty...
                        12-12-2020, 11:19 AM
                      • Antonynl
                        What are typical ripple voltages on a laptop motherboard?
                        by Antonynl
                        I have here a HP pavilion hp 15-cs2975nd with a 1.095v power supply that is driven by a FDMF3035. I do see about 80mV of ripple on my scope. I searched through the datasheet to find possible values of the ripple but I don't understand the datasheet well enough.
                        So I have two questions:
                        1) what is the typical ripple voltages of gpu/cpu on a laptop or pc mobo?
                        2) what would be the max ripple of a FDMF3035 that drives an output of 1.095V?
                        Would be nice to have a rule of thumb of say a percentage of the supply voltage to be an acceptable ripple voltage....
                        12-09-2022, 06:51 AM
