Audio Linear Power Supply (LPS)
  • Bugmanscj
    • Feb 2025
    • 6
    Hi: Found this forum fumbling over the net looking for replacement capacitors for a high quality 2uv ripple model Kaia, Core Audio Technology LPS. I bought it used on fleabay and figured I would have to recap and sure enough one of the 22,000uf 35V 105c caps is bulging. These supplies were made briefly around 2014 for MAC Mini audio servers, and were quite costly at the time ($1.7k), you know it's audio... I will use it for a video processor power supply to replace a switched version. I figure it's a low cost attempt to see/hear what difference it might make in my system. Plus I get to learn something regarding electronics repair. I've done quite a bit of it, but not in computers and sensitive devices. I'm getting an ESR meter (Atlas Peak) to test things out.
    In the search for capacitor replacements I'm restricted to 30mm dia. (cramped board) which really limits my choices to only Rubycon.
    Question: When you choose a capacitor for such and application do you look for high ripple current handling? I assume that a higher current capability would be best for a given temp specification. For example it can handle more current at the same temp as a lower amp rating. Thus the question.
    Thanks,
    • 31936
    thanks for the diameter,
    but you need to add if it uses 10mm pitch pins or screw terminals - among other info
    i have NEVER seen a large cap bulge btw, it should be physically impossible because they have a physical vent valve on the base usually.
    post photo's
    • Bugmanscj
      • Feb 2025
      • 6
      stj: They are 10mm pitch pins and it's 50mm in height. Hard to find anything else on these old caps from Nippon Chemicon except M-20% tolerance. See attached photos. The overview of the unit shows the purple large cap on the front right. The dome is raised a bit compared to the rest, so figuring that was starting to bulge (on it's way at least). The closeup (front left cap) shows it as well, plus it is an indentation about half way down on the right. Just not the same as the other caps.
      Am I over reacting to a slight deformation in the cap? I'll know a little more tomorrow when my amazonian Atlas Peak ESR meter comes in. Just being very cautious as this is powering a very expensive Lumagen Radiance Pro 4446.
        • 31936
        it does look suspect.
        cut the plastic cover off it to verify it.
        what is the series code? it's a 3 letter code probably ending in G
        is it KMG??
        • Bugmanscj
          • Feb 2025
          • 6
          KMG confirmed. I tried searching it at Chemicon but no luck.
            • 31936
            here
            • Bugmanscj
              • Feb 2025
              • 6
              Thanks. Doesn't have the 22000uf listed. Strange.
              • Bugmanscj
                • Feb 2025
                • 6
                is it KMG??
                I cut the cover off and found the metallic seal intact with no cracks/fissures along the breakable edges (the x pattern). I will report back if there are ESR issues, but I expect it will test OK. Something to keep an eye on over the next few years. Likely will examine yearly.
                • Tynan Dill
                  by Tynan Dill
                  Assuming...
                  11-22-2024, 01:46 PM
                • samson7point1@yahoo.com
                  Help troubleshooting an audio problem with an RCA SGT-250 CED Player
                  by samson7point1@yahoo.com
                  The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
                  The player processes the audio signal using two different reference frequencies. The "R"...
                  04-30-2024, 11:22 AM
                • caspian
                  What Zener Diodes on a Linear Power Supply
                  by caspian
                  Dear members,
                  I have a linear variable power supply with unknown brand name that I used for voltage injection.
                  Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                  In addition, I discovered that its zener diodes are defective.
                  I can replace the burned transistors.
                  But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                  Therefore, I cannot replace the zener diodes.
                  I do not want to test the zener diodes in a test circuit to discover their model or value.
                  no schematics are available...
                  05-26-2025, 12:38 PM
                  03-31-2024, 02:12 PM
                • thesame
                  2.1 audio sistem rezistor and zenner getting 90 celsius
                  by thesame
                  Is it normal for this type of 2.1 audio sistem for the 220 ohm resistor after the big capacitor 3300uf/35 v to have almost 90 celsius on thermal camera and also the zenner thats connected to it has the same temperature? Preamp is F4558 and TDA on the radiators....
                  05-15-2026, 11:52 AM
