Video Cards- How Hot is too Hot?
  • bigbeark
    • Jan 2010
    • 661
    I have here a PCI video card GFMX420PCI, which translates to an NVIDIA GeForce MX420 64MB PCI video card. I was using it on my ASUS CUR-DLS board in place of the onboard 4MB ATI Rage.
    It started to get flaky, so I replaced the 4 Canicon 6.3V 1000uf with Sanyo WGs.
    Tried some full-screen youtube video, worked great. Went to swap it out as I was going to test another card, and WOW it was hot. Probably 80C. It has the little 2-pin connector, so I could attach a 40mm fan. At present it's passive cooled heatsink.
    Why so much heat? Should I expect a PCI card to get hotter than an AGP card?
    The onboard rage cards don't even have a heatsink. Obviously this card fried the Canicons. Two of them had ESR approaching 1.00. Card is not burnt in any way.
    So is the card defective and am I wasting time adding a fan?
    Or are video cards expected to have short, hot nasty lifespans? Or should I look to some component that is adding resistance, and hence heat to the circuit? It does have one large MOSFET Niko L1084S DNA1327D84 and 2 Toroidal Inductors, but no parts
    show the effects of heat.j
  • Scenic
    o.O
    • Sep 2007
    • 2642
    Re: Video Cards- How Hot is too Hot?
    GF4 MX and GF2 MX (same thing basically) do get really hot (unless underclocked and undervolted).
    they either have a heatsink + fan (with a heatsink not much bigger than the GPU itself) or a passive heatsink only, which is 3 - 4 times as big as the GPU..
    GF2 MX400
    GF2 MX200
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      GF2 MX400
      GF2 MX200
      or both if i soldered a fan to the fan header holes on a passive card... and that will really keep it cool...
      sigpic
      (Insert witty quote here)
      • bigbeark
        • Jan 2010
        • 661
        Well, that explains it. My card looks like the top one, small heatsink, but NO fan.
        Thanks very much for your input! I ordered a fan last night!
        • 370forlife
          Large Marge
          • Aug 2008
          • 3112
          Video cards usually have a higher heat tolerance than cpu's, but sometimes the makers save a buck or 2 by putting a smaller heatsink on thinking you aren't going to use it to hard or they anticipate good airflow around the card.
