can i use through-hole Cap instead of SMD one?
    hi,
    i have a 7950GT graphic card and one of the electrolytic caps broken.
    C122 position - 100uf/6,3v SMD cap ... can i use a 100uf/6,3v through-hole? or i should order a SMD one? im asking cause i have some through-hole caps here, so i wouldnt have to wait to fix the card.
    thanks in advance
    Re: can i use through-hole Cap instead of SMD one?
    Yes you can, wont hurt to check continuity to the SMD pads first of course, but I'm 99% certain it will be ok...
      use a multimeter to see if the holes line up to the pads
      also, do you have the old cap? you might be able to resolder it back on.
      sigpic
      (Insert witty quote here)
        thanks for reply ratdude747 and Per Hansson... the problem is that i dont have a multimeter... so, can i solder the through-hole "legs" to smd pads and re-solder the smd cap after it arrives?
        thanks.
          wrong
          you might short something.
          get a multimeter or make a DIY contuinty tester using an LED, some wire, a 3-5V source, and a bit of solder...
          but you really need to get a multimeter... for stuff like this it is in the "gotta have it" category.
          sigpic
            wrong
            hmm, thanks for the info.
            but...just checking cause maybe i wasnt clear enought since english isnt my first language.
            i cant do the following? respecting correct polarity and specs(uf/v), of course.
            yep,its kinda sux, but i couldnt find smd caps in my town, so i´ll need to order online.
              Yes, you could do that. Cut the leads down to just long enough that you can bend them to fit to the length of the smd pads.
              Though i'm fairly sure that through hole spot matches up with the SMD ones. Do you know anyone who you can borrow a multimeter from? Even if they don't line up, that is obviously a silkscreening for a cap. Capacitors are passive devices, they don't conduct electricity between two points, so you can't short anything out with it.
                no, you would be shorting the pad to the hole, and who knows where they go... they could be different voltages... bending the leads sounds like a much better idea...
                sigpic
                  Thats what he was saying. He wanted to know if he could just solder a through hole cap onto the smd pads.
                    i thought he meant put it in the holes and solder bridge it...
                    sigpic
                      ahh, yeah that might not be good.
                        why not just make the holes with a drill?
                        hehe
                        don't do that
                          hehe
                          don't do that
                          you would be surprised how many n00bs around here have tried that sort of thing... the closest i ever did was drill a hole in a blank pcb to accommodate a larger lead... and that was done very carefully.
                          also do not drill out solder filled holes... bad idea...
                          sigpic
                            Board is set up to take either type of cap. Just use the 2 holes to the left of where the SMD was. Clean any excess solder off the SMD pads first.
                            Note that C138 on the far right is the same way. SMD but marked for both.
                            Toast
                            veritas odium parit
                              i would verify with a meter just to be safe... you never know...
                              sigpic
                                i can confirm its the same.
                                i've got a MSI GF 7900GT here. Layout in that area looks exactly the same. the pads for the surface mount cap are the same as the through holes ... i just tested it with my DMM.. (surface mount pads to the corresponding holes on the back side)
                                edit: just noticed.. even the cap position is the same.. C122 for the surface mount one
                                  then mount it in those holes and post the results
                                  sigpic
                                    No.... Really???
                                    DUH!
                                    veritas odium parit
