Asus strix rtx 2070 oc 8gb black screen and no detect
  • ying
    • Nov 2013
    • 21
    • España
    Hello, I have an 8gb asus strix rtx 2070 oc card which works perfectly but if I do a test with furmark or similar the screen goes black and stops being detected.
    If I restart immediately the card works again but sometimes it does not reach the desktop and other times yes, it seems that it fails when it is hot
    The temperatures are correct, I have also checked the memory chips and they are all good (I have used nvidia mats tool)
    It usually fails between 45 degrees and 60 degrees, randomly
    Greetings and sorry for my bad english
  • siedlik
    • Aug 2022
    • 11
    • United Kingdom
    Re: Asus strix rtx 2070 oc 8gb black screen and no detect
    I got a Palit rtx 2070, and I got the same issue. I did the mats test and its a pass.
    I have undercloked the GPU by 100MHz, and I have played games without any issues for hours. But when I closed the game, the screen went black and had to restart the PC.
    It happens at around 60 degree. I also got artefacts with that "XD" things, when running stock clock.
    So maybe at 60 degree the solder connections are getting bad, or bad memory or something.
    Will keep you updated.
    • ying
      • Nov 2013
      • 21
      • España
      Hi, thanks for the information.
      Today I have continued to do tests and after getting a newer version of the memory diagnostic tool I have seen that it gives me errors in three vram modules, then I replaced two of them but when I do the vram test again the same thing continues to appear number of errors
      After all of the above, I did a reflow of the GPU thinking that it may be a bad contact with the PCB, but the errors remain exactly the same, the number of errors does not change.
      • siedlik
        • Aug 2022
        • 11
        • United Kingdom
        I have done few more tests and I got a one module with errors.
        Will try to replace it and will see what will happen.
        Best place to get a D9WCW memory ? Aliexpress ?
        • ying
          • Nov 2013
          • 21
          • España
          I leave you a reliable seller who sells new modules
          https://a.aliexpress.com/_vMKfKd
          And this other reliable one that sells used modules
          https://a.aliexpress.com/_vrqDxr
          • ying
            • Nov 2013
            • 21
            • España
            Hello again, after a lot of checking and redoing the vram tests, now the previous vrams do not give me errors, but the first vram modules are giving me an error.
            The curious thing is that in the previous tests the number of errors is 288 and now it is the same number of errors again but with other modules, I don't know what else to try or what else to do.
            • ying
              • Nov 2013
              • 21
              • España
              Any ideas?
              • siedlik
                • Aug 2022
                • 11
                • United Kingdom
                Any ideas?
                Have you tried downclocking the GPU by 100Mhz ?
                • ying
                  • Nov 2013
                  • 21
                  • España
                  yes, same result
                  • siedlik
                    • Aug 2022
                    • 11
                    • United Kingdom
                    yes, same result
                    Have you checked the data lane in diode mode?
                    On a pcie it will be the 14 and 15 pin from the left.
                    It should read 0.4v
                    • ying
                      • Nov 2013
                      • 21
                      • España
                      It should read 0.4v
                      I could not answer before, I will check it and answer you, thanks
                      • ying
                        • Nov 2013
                        • 21
                        • España
                        yes the voltage is correct
                        • ktmmotocross
                          Boardkiller
                          • Feb 2014
                          • 3590
                          • slovakia
                          if your errors is shifting it is bad soldering under GPU
                            ASUS ROG Strix Notebook Strix Specification for Upgrade or Repair
                            This specification for the ASUS ROG Strix Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Strix boardview and Strix schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ASUS ROG Strix Notebook...
                            09-06-2024, 07:00 AM
                          • Technodoc
                            ASUS G614JZ-N3012W Rog Strix need some bios help, laptop black screen
                            by Technodoc
                            Asus laptop G614JZ-N3012W Rog Strix with i7
                            Mainboard G634J-PMV-VGT
                            6050A3441302-MB-A01
                            2023-02-10
                            Power button works okay....power light goes on
                            Red "bottom" leds go on
                            Charging led works
                            Fans do not spin, capslock key does nothing, screen stays black
                            I would like to program the bios again, to rule out a corrupted bios.
                            However I run into a size error
                            The bios chip is a Winbond 25R256JVEN
                            Used my Xgecu T-48 to read the bioschip (using select chip as type XM25QH256B @WSON8, read somewhere...
                            02-24-2025, 04:46 AM
                            ASUS ROG Strix GA15DH ROG 3700X Specification for Upgrade or Repair
                            This specification for the ASUS ROG Strix GA15DH can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ROG Strix GA15DH boardview and ROG Strix GA15DH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                            09-12-2024, 02:30 PM
                          • Themonster
                            Laptop Asus Strix G15 power up, but always black screen
                            by Themonster
                            Hi im Monster ("nickname"), i will explain what happens with this laptop pc:
                            Asus Rog Strix G15 : model = G512LW
                            The screen is not broken, almost not physically.
                            When i power up the computer this run perfect but nothing show in screen, also in HDMI port.
                            More or less 10 sec later, when win 11 is loaded , HDMI show things i mean user login in win 11.
                            Original or main screen doesn't works, anytime, but HDMI works fine when win11 load nicely.
                            When win11 is loaded , i check device administrator, and i found a system firmware error, so what...
                            01-19-2024, 04:00 PM
                          • ongobongo
                            Asus Rog Strix starts but no screen or other signs of life
                            by ongobongo
                            Hi Guys,
                            I'm trying to repair this Asus ROG Strix notebook for a longer while now.
                            Mainboard is G531GW rev. r1.6
                            When attaching power notebook straight up turns on but no picture or similar signs of life. Voltages are all there (VCCCORE, VCCSA, NVVDD, 1.05V, 1.2V, 5V, 3V, 12V …. Only VCCGT is missing, but that is ok as far as I read), no obvious shorts on any rails. CPU gets hot quickly without heatsink, GPU gets moderately warm and PCH gets warm as well. EC should be good: power button responds to a long press and after a while the CPU fan kicks in.
                            What I have found out...
                            08-06-2024, 01:13 PM
