System Info:
ECS K7VZM v1.0
Duron 800MHz
256MB SDRAM (PC133)
Diamond Video
I am looking to replace the capacitors on my nephew's older ECS K7VZM motherboard. It stopped booting recently -- it will power up to the BIOS but will not boot much beyond the hard drive detection. That's when my sister called me in. (Fun, huh!)
I found eight of the twelve G-LUXON 2200uF 6.3v 105C caps in the supply area have bulged. There are also seven G-LUXON 1000uF 6.3v 105C caps that I will also likely swap out, even though they have not bulged yet.
Using a crude inch ruler and converting, I get the following ballpark dimensions (do not take these as fact!):
G-LUXON 2200uF 6.3v 105C - ~10mmx20mm
G-LUXON 1000uF 6.3v 105C - ~8mmx16mm
I have looked at Digikey for Low ESR caps, but no Low ESR electrolytic caps in the 2200uF size showed up. I have reviewed the forum rules and gather that I can not ask for specific part numbers from distributers such as Digikey, but is it acceptable to ask questions about ripple current to help in my selection of replacement parts?
If so, I was told that higher ripple current == lower ESR. Is this correct? What ripple current would be good for replacement caps for this board. I saw some Nichicon "VR series" caps with 1000 mA of ripple current in the 10x20mm size. Is this high enough? There was also a Nichicon "PW series" cap that is taller at 10x25mm, but has 1440 mA ripple current. I don't think the height will be a problem considering the distance from the processor heatsink, but are these ripple currents anywhere near what I need?
Basically, what is a high enough ripple current to be acceptable?
I will try to post pictures later so others that may also have this ECS K7VZM board will know what to look for (though it wasn't hard to spot at all).
Thanks for any help you all can provide in my inquiries...
ECS K7VZM v1.0
Duron 800MHz
256MB SDRAM (PC133)
Diamond Video
