msi b450 tomahawk max ms-7c02 rev 1.0
  • Davemack69
    • Mar 2022
    • 38
    Have a msi b450 tomahawk max no boot dram led lit.
    I don't have any voltage on data lines to ram slots my working board has around 0.38v on data lines this is with no ram installed on both boards.
    I have a tested in diode mode and data lines read same on both boards.
    I have schematic and have tested voltages on all rails concerning the dram.
    Have I lost a voltage somewhere on a buck convertor or is cpu in sleep state maybe?
    Any ideas?
    • 21117
    Re: msi b450 tomahawk max ms-7c02 rev 1.0
    Schematic here https://www.badcaps.net/forum/showpo...19&postcount=2
    • The1
      Gigabyte B450 Aorus Elite CPU Dram led cycle
      by The1
      I have a Gigabyte B450 Aorus Elite Motherboard.
      Originally would not power on
      Reprogram EC eeprom and Bios eeprom with known good from this forum. Now error lights cycle between CPU and Dram.
      I have checked for shorts on all coils and found none.
      I have checked all power rail voltages and chips for pgood signal all good
      Checked CPU socket and found a damage pin, managed to clean and fix it should be making good contact now but no change. Dram and CPU are known good. Dram sockets look good.
      I can't see any...
      10-09-2023, 05:05 AM
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • HYDR
      Capacitor Value on MSI B450 Tomahawk Max
      by HYDR
      Heya guys. So, I recently just got a second hand untested motherboard from flea market. When I cleaned it, I think I ripped a capacitor near the CPU socket, I really want to fix it. I'm looking for guidance, thank you...
      02-01-2025, 06:27 AM
    • Gobbla
      b450 tomahawk max - dead
      by Gobbla
      hello everyone
      I got my hands on b450 tomahawk max - dead no power no post
      There is no short or any other indication of fault - no spillage no burnt
      I tried 750w power supply but still nothing - shorted correct pin but still no lights (they are some led at back and one small at front - test one)
      I found someone selling bios chips - BIOS CHIP - MSI B450 TOMAHAWK / GAMING PLUS / PRO CARBON AC / B450-A PRO MAX - is it worth trying guys ?
      thank you
      03-29-2021, 11:09 AM
    • Stanley1843
      Screen Display Vertical Multicolor Lines
      by Stanley1843
      Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
      06-29-2024, 11:54 AM
