Heya guys. So, I recently just got a second hand untested motherboard from flea market. When I cleaned it, I think I ripped a capacitor near the CPU socket, I really want to fix it. I'm looking for guidance, thank you
Capacitor Value on MSI B450 Tomahawk Max
by PrologHi people, I hope this is the correct spot to post this, I'm new to the forum.
I have found the board schematic (attached), but there does not seem to be a boardview available. I have never... -
by Gobblahello everyone
I got my hands on b450 tomahawk max - dead no power no post
There is no short or any other indication of fault - no spillage no burnt
I tried 750w power supply but still nothing - shorted correct pin but still no lights (they are some led at back and one small at front - test one)
I found someone selling bios chips - BIOS CHIP - MSI B450 TOMAHAWK / GAMING PLUS / PRO CARBON AC / B450-A PRO MAX - is it worth trying guys ?
thank you -
by chth96I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
I know that these capacitor will not last as long as nichicon capacitor...-
by chth96I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...-
by chth96When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
Rubycon YK DataSheet (b...-
- Loading...
