help repairing Gigabyte gv-n105toc-4gd
  • nvidiauser
    • Mar 2022
    • 7
    • Madrid
    Re: help repairing Gigabyte gv-n105toc-4gd
    Originally posted by klendatu
    hi
    otherhands does the card works ?
    if it does u can try to reflash the card...
    did u try msi afterburner and try to use your own def for fans ?
    Thanks for your reply!
    Yes, otherhand of graphic card works fine.
    So I tried reflash bios, try afterburner or Gigabyte software, but don´t work.
    I try to test fan pin (there are 4) and the pin 3v (pin 2) show 0,12v...
    • klendatu
      • Mar 2022
      • 45
      • france
      so if i understand your fans spins but never stops and the rest of the card works normally ?
      the 3.3 seems commanded by D504 U509
      • klendatu
        • Mar 2022
        • 45
        • france
        question
        what are the size of c825 c674 ? 201 or 402 ?
        if those sizes where to find a cheap price seller in aliexpress ?
        only find those sizes on expensives books
        ty
        • nvidiauser
          • Mar 2022
          • 7
          • Madrid
          Hi.
          No, fans aren´t spin... fans only spins just a second when I power on the computer...
          U509 is empty on this pcb... D504 shows 0.12v in pin2 and 3, pin1 shows 0v
          Some things on this pcb are diferent... I think that I nedeed boardview of GV-N105TG1-4GD but I can´t find in nothing place
          Thanks for you support!
          • klendatu
            • Mar 2022
            • 45
            • france
            fans starts to spin and stop at boot thats normal
            after they must go on about 60 61 degres...
            test it with occt but dont pass 75 degres....
            the limits of gpus are abt 80 degres
            • klendatu
              • Mar 2022
              • 45
              • france
              #26
              btw
              does someone got dead pcb to send me ?
              just to recover missing capa that i need....
              ty fa
              • klendatu
                • Mar 2022
                • 45
                • france
                #27
                Originally posted by benwaterson
                Ah sorry, I misunderstood.
                If you are pulling components from another board then it would be helpful to have a schematic for that board as well, otherwise its hard to know.
                well only find 1 220nf in the right size
                most that i found are up size.... think i ll be able to mount them....
                otherwise is it possible to put 100nf in place ? got plenty
                of course it allways to mount 2 on //
                the only pb is mechanical should mount half pin each.... maybe more risk of arrachment
                • klendatu
                  • Mar 2022
                  • 45
                  • france
                  #28
                  re
                  i look the 2 ways.... easier to put 1 in higher size...
                  • klendatu
                    • Mar 2022
                    • 45
                    • france
                    #29
                    ******repaired*****
                    that was the missing caps in pcie data rail
                    • Sarehman
                      • Oct 2022
                      • India
                      #30
                      Could anyone share impedence values of all coil of this card GV-N105TOC-4GD
                      most important is GPU impedence???????? thanks.
                      • ilod
                        • May 2020
                        • 3
                        • Israel
                        #31
                        This boardview should work
                        Sorry for super late reply but how do i open this? donwloaded teboview and it asks for a password
                        • Xaspy
                          • Russia
                          #32
                          Hi! May be its late, but I found boardview for that videocard.
