help repairing Gigabyte gv-n105toc-4gd
  • nvidiauser
    • Mar 2022
    • 7
    • Madrid
    Re: help repairing Gigabyte gv-n105toc-4gd
    Originally posted by klendatu
    hi
    otherhands does the card works ?
    if it does u can try to reflash the card...
    did u try msi afterburner and try to use your own def for fans ?
    Thanks for your reply!
    Yes, otherhand of graphic card works fine.
    So I tried reflash bios, try afterburner or Gigabyte software, but don´t work.
    I try to test fan pin (there are 4) and the pin 3v (pin 2) show 0,12v...
    • klendatu
      • Mar 2022
      • 45
      • france
      so if i understand your fans spins but never stops and the rest of the card works normally ?
      the 3.3 seems commanded by D504 U509
      • klendatu
        • Mar 2022
        • 45
        • france
        question
        what are the size of c825 c674 ? 201 or 402 ?
        if those sizes where to find a cheap price seller in aliexpress ?
        only find those sizes on expensives books
        ty
        • nvidiauser
          • Mar 2022
          • 7
          • Madrid
          Hi.
          No, fans aren´t spin... fans only spins just a second when I power on the computer...
          U509 is empty on this pcb... D504 shows 0.12v in pin2 and 3, pin1 shows 0v
          Some things on this pcb are diferent... I think that I nedeed boardview of GV-N105TG1-4GD but I can´t find in nothing place
          Thanks for you support!
          • klendatu
            • Mar 2022
            • 45
            • france
            fans starts to spin and stop at boot thats normal
            after they must go on about 60 61 degres...
            test it with occt but dont pass 75 degres....
            the limits of gpus are abt 80 degres
            • klendatu
              • Mar 2022
              • 45
              • france
              #26
              btw
              does someone got dead pcb to send me ?
              just to recover missing capa that i need....
              ty fa
              • klendatu
                • Mar 2022
                • 45
                • france
                #27
                Originally posted by benwaterson
                Ah sorry, I misunderstood.
                If you are pulling components from another board then it would be helpful to have a schematic for that board as well, otherwise its hard to know.
                well only find 1 220nf in the right size
                most that i found are up size.... think i ll be able to mount them....
                otherwise is it possible to put 100nf in place ? got plenty
                of course it allways to mount 2 on //
                the only pb is mechanical should mount half pin each.... maybe more risk of arrachment
                • klendatu
                  • Mar 2022
                  • 45
                  • france
                  #28
                  re
                  i look the 2 ways.... easier to put 1 in higher size...
                  • klendatu
                    • Mar 2022
                    • 45
                    • france
                    #29
                    ******repaired*****
                    that was the missing caps in pcie data rail
                    • Sarehman
                      • Oct 2022
                      • India
                      #30
                      Could anyone share impedence values of all coil of this card GV-N105TOC-4GD
                      most important is GPU impedence???????? thanks.
                      • ilod
                        • May 2020
                        • Israel
                        #31
                        This boardview should work
                        Sorry for super late reply but how do i open this? donwloaded teboview and it asks for a password
                        • Xaspy
                          • Russia
                          #32
                          Hi! May be its late, but I found boardview for that videocard.
                          • DynaxSC
                            GIGABYTE GA-H110M-S2 - Stuck at Debug Code C2 - don't like Patriot Viper Steel RAM but works with G.SKILL
                            by DynaxSC
                            I discovered a strange behaviour of GIGABYTE GA-H110M-S2 board.
                            General test conditions:
                            - Tested with Core i5 6500 and Core I7 6700K - no difference
                            - Default BIOS settings, but tried also altering several memory setting - does not change anything
                            What is wrong:
                            With BIOS F1 and F2 the board normally POST's and boots to Windows 11 with 2 x Patriot Viper Steel PVS416G440C9K RAM (4400MHZ, Samsung B-Die chips)
                            When BIOS upgraded to anything above F2 (ie. F20-F27b) the board POST stucks after 3 Debug Codes on Code C2
                            03-21-2025, 06:23 PM
                            Thermal pad thickness for various laptop GPU / Graphics Cards
                            ASUS Dual RTX 2070 OC 8GB
                            ASUS ROG STRIX RTX 3080 OC
                            ASUS ROG STRIX RTX 3090
                            ASUS TUF Gaming RTX 3080 OC Edition
                            ASUS TUF GTX 1660 S-O6G GAMING
                            EVGA RTX 3060 Ti XC GAMING 8GB
                            EVGA RTX 3060 XC GAMING 12GB GDDR6
                            EVGA RTX 3080 FTW3 ULTRA GAMING
                            EVGA RTX 3080 TI FTW3 ULTRA GAMING
                            EVGA RTX 3090 XC3 ULTRA GAMING 24GB
                            Gainward RTX 2080 Phoenix GS Specs
                            Gainward RTX 3070 Phoenix 8GB
                            Gainward RTX 3080 Ti Phoenix
                            GIGABYTE AORUS RTX 3080 MASTER 10G
                            02-09-2024, 08:08 AM
                            A Dead/DOA Gigabyte GP-P450b 450W ATX PSU
                            by momaka
                            More eBay specials: this time a Gigabyte GP-P450b 450W ATX PSU for $8 with free S&H. Listed “For part/not working”, as usual. Showed up in a beat up EVGA box without any padding… but that's understandable given the total price. PSU made it out fine without damage. It's a non-modular (yay!), pretty modern-day looking PSU with a black paint and all black cables (meh, not my favorite, but figure it's good to keep a few of these in case I do need one for a more modern PC build, just so my old gray boxes don't look too odd in there.)
                            And a shot of the label:...
                            01-26-2022, 03:26 AM
                          • nikovmiroslav
                            Gigabyte A5 X1 Need Bios
                            by nikovmiroslav
                            Hi Everyone,I need help with this strange Gigabyte laptop,it turns on with black screen and after 30sec fans on the Max for few seconds and it shuts down,I think the bios is bricked,They say it is Clevo under the hood,there is nowhere on motherboard what is the model which is strange,i will write S/N and P/N from the motherboard,thats only what is writen there and upload old bios,if anyone can help,Thanks!
                            Gigabyte A5 X1
                            From motherboard:
                            S/N: 1TNH55ER1350895
                            P/N: 6-77-NH55ERQY-D02-2CGB
                            On sticker from the back of the laptop:
                            S/N: SN21351J000657...
                            08-24-2025, 09:15 AM
                            Gigabyte AORUS 15X Netbook Specification for Upgrade or Repair
                            This specification for the Gigabyte AORUS 15X Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15X boardview and 15X schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Gigabyte AORUS 15X Netbook...
                            09-07-2024, 07:19 AM
