ASUS P6X58D Premium - No Display / MemOK LED
  • SashaG
    • Feb 2022
    • 11
    • Philippines
    I have an ASUS P6X58D Premium motherboard that is not posting and gives no display.
    First I thought that it was corrupted bios so I flashed the latest bios using an external programmer. Still nothing. So I thought that the bios chip is faulty. Used a different chip still the same result and used the original chip in a different motherboard and it worked, so its not the chip.
    CPU and RAM are known working (tested on 2 motherboards). No bent pins in socket.
    What I noticed is that the MemOK light stays on and according to the manual its some sort of compatibility issues with the RAM and bios version. However, I flashed the latest bios and the RAM Im using is in the QVL.
    I've read that this is a common issue but I haven't found the solution yet.
    I've tried pressing the MemOK button just as what is said in the manual and it cycles through the tests (different blinking speeds) until it comes to the point where it stays on again and still no post.
    Any help is much appreciated. Thanks.
  • razor_amd
    by razor_amd
    12-15-2020, 07:07 PM
  • mkdj
    What should I do after having flashed a BIOS?
    by mkdj
    Dear all,
    I did my first laptop repair related to a BIOS issue. Laptop is a Lenovo ThinkPad T480, and was not booting. With my brand new programmer, I did a back-up of the current not working BIOS, erased the BIOS chip, and flashed this dump: https://www.badcaps.net/forum/troubl...83#post3686683
    Now the laptop works fine, I can access BIOS and boot on a USB drive. But I read stuff about DMI, and...
    09-09-2025, 09:45 AM
  • throwaway327
    by throwaway327
    Model No: RC72LA
    Serial No: SBNVKD001014459
    06-18-2025, 05:52 PM
  • Loli Popu
    DELL 5590 LAPTOP DEAD AFTER BIOS WRONG FLASHED
    by Loli Popu
    Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
    12-13-2024, 03:28 AM
  • drux
    Alienware Aurora R15 accidentally flashed with XPS 8960 BIOS
    by drux
    I've had an ssd that was previously used on dell xps 8960 and then it was installed in Alienware Aurora R15(intel version). On first windows boot in R15 windows started bios update and loaded bios for xps 8960(r15 and xps8960 essentially have same motherboards).
    Now it has xps 8960 bios that looks different from alienware bios and when I'm trying to run bios update files for R15, I get unsupported platform error.
    These models have AMI/Aptio BIOS.
    Tried to edit product info with DMI Edit to change values back to Alienware R15, but it does not want...
    11-03-2024, 01:18 AM
