ASUS Sabertooth 990FX REV.2 bios chip problems, probably socket shorted?
ASRock B550 PG Velocita
Ryzen 9 "Vermeer" 5900X
Arc A770 16 GB
eVGA Supernova G3 750W
Alienware AW3423DWF OLED
"did I see a chair fly? I think I did! Time for popcorn!" -ratdude747Comment
Re: ASUS Sabertooth 990FX REV.2 bios chip problems, probably socket shorted?
Nothing works.
I changed the bios chip, the Winbond one, and nothing changed.
When I plug off the power cord, and after a while I power on, Bios need to be recovered pressing F1.
Then every time I have to load the OC profile and it works.
Annoying.
But I don't have other idea.
Cmon battery is ok, must be a motherboard problem then, I don't really know what to do.Comment
Hi there,
I have news.
So the new Winbond Chip is arrived, I changed it and nothing changed. Like always, when I unplug the power cord and reattach it, my BIOS ask me to be recovered with F1 button.
But there is a new. I wondered a thing.
Yesterday, after about a week that the PC was took away, the FIRST power ON goes successfully. No ask to recover bios. And the bios setting was perfectly there, all setting correctly loaded. So I decided to make another try. Before going to sleep I unplug the power cord and today, after about 10 hourse of motherboard without power supply, I tried to power on the PC. And here we go, another flawless start. No ask to recover bios, bios loading and overlclock perfect.
So, what can we say here?
For me, bios can work OK, the original chip and the new one, can store informations for days, thanks to the correct function of the battery.
If i unplug for a long time the PC, the bios can load correctly.
But If I unplug the power cord only for some minutes (ore maybe hours) motherboard ask me to "recover bios pressing F1".
So I pass the ball to you, any ideas???Comment
by DynaxSCHi
I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6... -
by SMDFleaCommon SPI bios chip programming Questions and Answers
Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
A: If you can`t read from it how do you expect to write to it ?.
Q: Why is my bios chip unreadable ?.
A: The programmer is faulty or has a worn or broken zif socket.
The USB cable is frayed,connector pins worn or some other physical damage.
Not enough amperage or voltage to power the programmer properly.
Bad...-
Channel: BIOS Requests ONLY!
09-02-2021, 04:40 PM -
by BerunHello All,
I tried to read the the BIOs chip(GD25B127DSIG) on the mainbord of an HP EliteDesk 800 G6 mini, because the BIOs had an Admin Lock and I got the "HP Endpoint Security Problem" Screen at every startup which is not very useful when I want to use the PC as a Compute Unit for my home media system somewhere in the cellar, so it should perform a restart without any interactions.
I only have the CH341APro Programmer available and did the 3V hardware Mod on it before I tried to read the BIOS chip.
I read the Chip on board 8 times (with power... -
by JoWedHello Community,
I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...-
Long story short:
- dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
- gave the computer to his son a couple years later
- son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
- too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
(seems like the story was not that short)
He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8... - Loading...
