RX580 Gigabyte Gaming 8GB - Micron - Boots only if I do the BIOS short
  • Goblin999
    • Jan 2022
    • 79
    • Romania
    So I just got off ebay this Gigabyte RX580 Gaming with 8GB Micron memory . The thing is the card only starts if I do the paper clip short on BIOS . I booted using the paper clip method in Hive , reflashed the original BIOS again but still won`t boot unless I do again the short on pins 1+5 . Anyone knows why , or how should I recover from this ? Thanks
  • Bozog
    • Jan 2022
    • 125
    Re: RX580 Gigabyte Gaming 8GB - Micron - Boots only if I do the BIOS short
    Pins 1 and 5 are chip enable and mosi, why would you short those?
    You can check the resistors in the chip enable line, seems unlikely the chip itself is bad since you can get it to boot and flash, but you never know. Does this card not have dual-bios and a switch?
    • Goblin999
      • Jan 2022
      • 79
      • Romania
      So I shorted the pins marked with red circle , and managed to reflash BIOs 2 times (once I flashed a hynix memory by mistake)- and afterwards I flashed the original BIOS from gigabyte forum . The thing is the pc won`t boot unless I do again the short on those pins . Unfortunately it is a single mode BIOS (no switches) . Can you point me where I should check the resistors ? Thanks
      • Goblin999
        • Jan 2022
        • 79
        • Romania
        This is how it reads the card after booting(in HiveOS) with those pins shorted for a while :
        Radeon RX 470/480 8192 MB · AMD/ATI
        Micron MT51J256M32 · xxx-xxx-xxx
        • Goblin999
          • Jan 2022
          • 79
          • Romania
          Also measured resistance on this little resistor and it gives 1 kohm
          • Bozog
            • Jan 2022
            • 125
            Looks like its one of those 4 resistors above pin 4, they should all be 33r, you should also be able to measure the 2k2 pullup resistor between pin 1 and pin 8 on the bios chip.
            • Goblin999
              • Jan 2022
              • 79
              • Romania
              all 4 resistors above pin 4 have 33 ohm r, I don`t know exactly which is the 2k2 pullup resistor between thos pins
              • Bozog
                • Jan 2022
                • 125
                The 1k resistor looks like its the pullup anyway. Well then I have no idea, nor do I have any idea why you are shorting chip enable and mosi, or why that would make it boot...I think maybe this is a red herring and shorting those pin is not what is making it work.
                • Goblin999
                  • Jan 2022
                  • 79
                  • Romania
                  Also the little led from the 8 pin PCI power doesn`t show any color
                  • Goblin999
                    • Jan 2022
                    • 79
                    • Romania
                    what do you mean by "red herring" ? I am a total newbie regarding gpu repaird
                    • Bozog
                      • Jan 2022
                      • 125
                      A red herring means a misleading clue
                      • Goblin999
                        • Jan 2022
                        • 79
                        • Romania
                        Thanks for enlighting me . I really don`t know where to look further ...
                        • Bozog
                          • Jan 2022
                          • 125
                          Need to start from the beginning, what actually happens when the card doesn't work?
                          • Goblin999
                            • Jan 2022
                            • 79
                            • Romania
                            The pc won`t boot - Display screen stays black . If I short those 2 pins (I read on internet that when card is bricked shorting those pins helps you unbrick it) , everything goes well -pc boots , cards is discovered in HiveOS , etc
                            • Bozog
                              • Jan 2022
                              • 125
                              What it works every time when you short those 2 pins? I am so not convinced
                              • Goblin999
                                • Jan 2022
                                • 79
                                • Romania
                                Yes , it boots every time when I short those pins )) Also a facut that is strange is if I don`t insert the 8pin power supply cable in the slot but card is inpci riser the white led lights up white . When I insert the 8pin power cable it doesn`t lights at all
                                • Bozog
                                  • Jan 2022
                                  • 125
                                  Just leave them shorted then
                                  • Goblin999
                                    • Jan 2022
                                    • 79
                                    • Romania
                                    That is clearly not the solution I wanted to find out why is this happening ? I put osciloscope on the pin 1 of bios and nothing happens . It is such a strange thing
                                    • Bozog
                                      • Jan 2022
                                      • 125
                                      Can you try it as a secondary gpu, use on-board or another gpu as primary?
                                      • Goblin999
                                        • Jan 2022
                                        • 79
                                        • Romania
                                        I use on board primary always . When I do not short those pins it is simply not booting . doesn`t get the motherboard pass bios - the screen just stays black
