New Members
This site is paid for using my salary. Please consider making a monthly donation of $8 to support the site. I will add supporters who donate monthly to the ad-free group
Please also introduce yourself here Introduce yourself here.
And finally, Read the Forum rules here.
RX580 Gigabyte Gaming 8GB - Micron - Boots only if I do the BIOS short
Re: RX580 Gigabyte Gaming 8GB - Micron - Boots only if I do the BIOS short
Here is my theory about this error, I may be very well wrong but I'll give it a go.
Pin 1 of the BIOS is the enable signal. It is active low
I am assuming that your shorting of the pins (1-5) is somehow grounding the pin 1 therefore the chip gets enabled. Therefore the card is able to boot. I am not sure of the model of your bios chip but maybe grounding pin 1 (short to pin 4) would have the same effect? Not sure
If the above assumption is correct than it means that the Enable signal is somehow wrong.
Enable signal is generated by the GPU, goes through 3.3v and also has a pull-up resistor.
You already measured this resistor (R35) to be 1k. According to a schematic on a similar card this value should be 2.2k. I am not sure if this could be an issue. Do you see 3.3V on this resistor?
If both resistance values are ok then it would be the GPU, or the GPU connection that is the problem.
I see exactly what you are thinking, but I am pretty sure with SPI the chip enable signal has to be correctly timed, it is part of the protocol and to prevent spurious reads/writes, you cannot just randomly pull it low and read/write the entire chip.
Of course I could be wrong, feel free to enlighten me
I took a brake from it as it gotten me nowhere , but I will check it again later today
Also when booting after I short the pins (pin 1+ pin 5 or pin 8- has same effect) . it looks like this in HiveOS , but when starting to mine the GPU chip it gets pretty hot but I presume there is an error somehow on a sensor reading because the chip cannot go 511 degreees celsius
Well I have absolutely no expertise in this area, this was just my train of thought. However it is a fact that when those pins are shorted this card boots somehow. I am just curious to understand what is happening.
Might be worthwhile to check with an oscilloscope what is happening on data pins with and without the short.
Also tried the osciloscope on pin 1 of the bios chip and nothing happens (without bios being in short)
Hello i got a card with 12V short, found an IC blown Q510, remove it short persist, found that the short is on 12V GPU, remove all the Mosfets and the short still there, i inject 1.5V to the line and i got 1A of consumption, nothing getting warm, this could be the GPU itself?...
Hey!
I have a problem with Gigabyte Aorus 1080. The card seems fine (expected resistance on vcore, pex, 5v, 1.8v, 12v and reset) except for a dead short on vmem (FBVDD). It's interesting failure mode, cause usually (in my experience) when memory fails it still retains a few ohms - this one is literally a dead short.
I removed the inductors and tried inject voltage (0.8 V at 6 A) which only seemed to warm up the cables to the card while the card itself didn't show any hotspots.
Is there any way to narrow down the search for a short? I would prefer not to remove...
I picked up a faulty Sapphire Nitro+ RX580 8GB. It was pretty clean, expect from what looked like residue around the thermal pad between the rear of the board and backplate for helping to cool the memory, so I am guessing it had some liquid spilled on it at some point. All I was told is "the screen went black when playing a game".
The 12V external power appears to have a short. The two fuses have blown (circled in red on the image) and I am measuring low resistance (1.6 Ohms) on the output of the fuses to ground. When I inject power at the output of the fuses,...
I'm looking for a extreme high current short killer solution for a reasonable cost.
I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
After taking off the socket, the shorts dissappear again.
The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
